Question about Janome Sewing Machines
I have a Janome 3160 QDC and the bobbin case has slipped. i removed it and cant insert it corectly
  • 475 Answers
You may get help for that on the Janome web site, the bigger manufacturers often have a support page or download instructions
Posted on Apr 28, 2017
  • 5 Answers
SOURCE: Bobbin problems
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble. tjsews2008@gmail.com
Posted on Mar 02, 2009
Mongo32
  • 111 Answers
SOURCE: inserting bobbin
needle's in backwards
Posted on Jun 01, 2009
  • 1564 Answers
SOURCE: janome 3160 qdc drop feed dogs
Look on the back side for a slide type switch.
Posted on Aug 04, 2012
  • 1564 Answers
SOURCE: bobbin case problems
Oh wow. That's definitely not good. Well you'll need to replace the bobbin case, and needle plate. Even the slightest burr can cause havoc. you could try smoothing down burrs with some fine sand paper but you'll need to replace the case eventually if you can't get this problem identified and fixed.
Next look for a build up or stray threads under and around the needle plate/bobbin area. Make absolutely certain you have the right needles for your machine.
Posted on Sep 08, 2012
  • 5 Answers
SOURCE: My Janome 3160 QDC will not work lcd screen comes on but buttons won't work and machine will not sew
Try unplugging the cord from the wall (and from the machine if possible) let it set for 10-30 minutes and then try it again. This allows the circuits inside to lose all of their electricity and reset.
Posted on Jul 17, 2016
My Janome harmony sewing machine is totally jammed
1. Try to take out the needle. If this doesn't work take out the bobbin carefully so you don't get stuck by the needle. Also remove the bobbin case. (thing that the bobbin sets in)
2. Once you have the two out try to turn the hand wheel. It should turn.
3. Replace the needle. Clean the bobbin area thoroughly. Oil the race where the bobbin case rides. One drop is all it needs.
4. With the needle inserted and no bobbin inserted turn the hand wheel.
5. If it turns ok then insert the bobbin case and bobbin.
6. Does it turn? If it is a problem turning then you will need to get it timed from a maintenance person.
Nov 13, 2016 | Janome Sewing Machines
Jul 17, 2016 | Janome Sewing Machines
Not sewing stich
Don't know the make/model of your machine...
The bobbin case has a latch that you need to hold open until it is in position. When you let go of the latch, it should be secure.
Inserting the Janome Front Loading Bobbin Case
Here's a manual for your machine:
http://www.singerco.com/support/instruction-manuals/search
http://www.getcrafty.com/forum/share-craft/8131-help-big-problem-singer-7033-sewing-machine.html
https://www.reddit.com/r/sewhelp/comments/1kcovm/singer_7033_bobbin_thread_wont_stitch/
Apr 07, 2016 | Sewing Machines
Bobbin shuttle fell out
About 8,950 results (0.69 seconds) Search Results
    Inserting the Janome Front Loading Bobbin Case - YouTube
    ? 1:46
    https://www.youtube.com/watch?v=Mz7-k4G9HFg
    May 8, 2013 - Uploaded by Janome Canada
    Learn how to insert a front loading bobbin case. It's easier than you might imagine. Janome ... Janome HD-1000, Beginnersewing machine.
    How Do I Fix My Sewing Machine: Troubleshooting Your ...
    www.craftsy.com > Blog Home > Sewing Blog
    Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ...Take the Trouble Out of Sewing Machine Troubleshooting! ... has fallen out of the take-up lever, which can happen if the machine was jammed along the way. ... of thread through the bobbin winding tension at the top of the machine.
    Bobbin Case Keeps Falling Out of a Sewing Machine ...
    www.thriftyfun.com/Bobbin-Case-Keeps-Falling-Out-of-a-Sewing-Mach...
Feb 09, 2016 | Janome Hd1000 Sewing Machine
Janome bobbin problems
try getting a new bobbin case
Mar 23, 2014 | Sewing Machines
Hello dear
have you tried changing the needle?
have you tried adjusting the top thread tension?
it might be the needle and the thread are not compatable,, the needle may be to light for the thread.
if the suggestions don't help, sew on the sewing machine till it makes the loop and then stop the machine and take it to the repair man and let him see the loop and then ask him why it's making the loop.
Jul 25, 2013 | Janome Sewing Machines
Janome 3160 qdc drop feed dogs
Aug 04, 2012 | Janome Sewing Machines
Corect threading needle for sewing on brother lx3125
please follow the instruction
1. raise needle to its hieghest position
2. remove hand hole cover plate
3. remove bobbin case from shuttle, pull open latch of bobbin case
4. pull bobbin case straight out of shuttle
5 insert bobbin into bobbin case making sure thread is coming from bobbin.
6. pull thread through slot
7. pull thread under tension spring
8. holding latch open position case into shuttle, and release latch. case should lock into place when latch is released
happy sewing.
regards please rated me.. thanks
Mar 31, 2009 | Brother Sewing Machines
Sewing Machines Logo
49 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
