Question about Garden
I need the pin that holds the bar on a kobalt 80 volt chain saw
  • Garden Master
  • 3,828 Answers
If you cant buy one
find the metal drill bit that has the same diameter shank
and cut to length
i need the pin that holds the bar on a kobalt 80 v - index-ga5va5500wygjikc4v5xzqjs-2-0.jpg
Posted on Apr 26, 2017
How do I easily assemble pole saw?
pole saw is a wonderful machine that has a small curved saw blade mounted on its long handle and used mostly for pruning hard-to-reach branches. Now, if you have already learned about its functionalities and got a hold of them, you must be very excited to use it. But, working with a pole saw can never be easy without its being ready. A proper assembly is a key to that readiness.
No rocket science indeed! We're explaining the whole job easily and legibly.
STEP 1 Knowing the parts and components is a crucial factor. You should know what an average pole saw includes and make sure you have got all of them. A usual pole saw consists of the main body, pole saw, chain, bar, cover and hex key that contains screwdriver attachment.
STEP 2 The next step is to uncovering sprocket on the main body. It can be done by taking the hex and unscrew the pocket over the bolt. Rotate the hex in an anti-clockwise direction and take the cover out of the body.
STEP 3 As the cover is removed, the following task is to organize the chain and straighten it. In this case, if the chain should be in the right travel direction. If it is not in the right direction, you should loop over the chain and set in a way so that the teeth adjust with the bar.
STEP 4 When the chain is set properly, you should link the chain drives to the bar groove afterward. You should connect the chain carefully and ensure that it is attached accurately. Otherwise, a chain that is not fixed correctly may lead to a serious accident.
STEP 5 After the attachment, a loop remains at the end of the bar. Now, take the bar and place the loop on the sprocket and adjust the chain with it also. Before you do it, you should loosen the tensioner pin with the help of your fingers. It is done to confirm that the tensioner pin passes through the tensioner hole on the bar.
STEP 6 As the chain and bar are fixed to the sprocket, it is required to tighten the chain tensioner screw so that the bar and chain can hold and stay on the sprocket. The screw needs to be tightened completely in this matter.
STEP 7 This step involves covering the sprocket. Take the cover and insert rear tab into slot. Just placing it in the slot does not secure its placement. So, to attach the cover take the hex key, put in the bolt and turn it into clockwise direction but not too tightly. The cover is lightly fixed so it can create room to work with the tensioner.
STEP 8 You should remove all the slack from the chain by turning the chain tensioning screw clockwise. By doing so, the chain and bar stay in its place safely. After this, tighten the sprocket cover bolt using the hex key again.
Source:
Step By Step Guide to Assemble Pole Saw
Apr 14, 2018 | Garden
The chain keeps coming lose and falls off
Make sure chain tension on the bar is correct and then the 2 nuts holding the bar is correct, Youtube has alot of videos on how to set chain tension as well as the Oregon website
Aug 27, 2014 | Craftsman sears 18" Chain Saw Chain (...
Kobalt manuals
bar and chain oil or 2 cycle oil... take your pic as they are different, ones for the engine and ones for the bar/chain
Aug 23, 2014 | Garden
How to put the chain back on a 16" Poulan electric chain saw
its probably like the gas model. so you remove the 2 nuts holding on the side cover of the blade side, remove the cover and the blade and chain. To fit back, slacken the adjuster screw a little bit, or if fitting a new chain then a fair amount, as you have to be careful that the pin on the adjuster fits into the proper hole on the saw bar, as you fit back on the bar, of which you have already cleaned out the grooves. supporting the bar in the slackest position, fit on the chain, making sure that the cutting edge at the bottom is coming towards the motor. Then slide the bar and chain away from the motor to take up the slack, then fit back the metal guide in the original position, fit cover with the adjuster pin in its hole on the bar, and replace the 2 nuts almost tight but slack enough to use the adjuster to set the chain to cutting position..slightly sagging on the sprocket nose type, or snug on the solid nose type..then tighten the cover 2 nuts firmly but not excessively as that will damage the machine..NB the bar & chain depends on the adjuster, not on the nuts tightness to maintain tension
Jul 14, 2014 | Poulan 14 in. 2.0 Peak Horsepower Electric...
How to tighten chain on black and decker cordless pole saw
A properly-tensioned chainsaw chain should still be just a little loose on the chainsaw guide bar, but the chain needs to be tight enough that you can't pull the drive links out of the bar nose.
More details how to tighten the chain on black and decker cordless pole saw go to the link Practical Black and Decker Pole Saw Review
Jul 21, 2013 | Black & Decker Black Decker NPP2018B 18...
How do I tighten chain after removing the cover
All the saws I use that do not need the cover removed to tighten the chain. If the tightening parts are in the cover you can't adjust the tension with the cover off Other saws the pin is on the saw side To tighten the chain there is a pin that fits into a hole on the bar. Turn the adjusting device to move the bar forward to tighten the chain. If you get it too tight it will not move.
May 08, 2013 | Worx (16") 3.5 HP Electric Chain Saw -...
Chain fell off and I can't get it back on.
Turn the saw off. Look for several nuts on the right side of the saw that hold the cover on and the blade to the saw. Loosen these nuts, and before taking the cover off, loosen the chain adjuster by turning it (usually a screw head on the same side, or on the front of the saw as you look down the blade towards the saw.) Loosening the chain adjuster moves a pin that goes into the bar (the part the chain rides around when operating) to push it away from the saw to tighten the chain when you are tightening it. Take the cover off, and put the chain around the sprocket at the back like a bicycle chain, and then while holding the bar (sometimes a partner helps) parallel to the saw and outward away from the front of the saw, align the bottom parts of the chain inside the bar guide slot all around the bar, holding just enough tension that it doesn't fall off the sprocket or get misaligned in the bar guide. Try moving the chain a little bit to make sure it is not binding on anything. If it doesn't move at all, make sure the chain brake is not on. Once it is moving smoothly, put the cover back on, and begin to hand tighten the nuts. Just before they begin to get tight, eyeball where the chain tensioner pin is in relation to the hole it is supposed to go in. Adjust the chain tensioner screw to move the pin towards the hole. When it pops in the hole, continue tightening the nuts by hand until tight. Now you and your partner can let go of the bar. Adjust the chain tensioner for the proper tension in the chain, not too loose, not to tight, refere to your manual. Finish tightening the cover nuts using the universal wrench to the specifications given in the owners manual.
Sep 06, 2011 | Poulan 14" Electric Chainsaw
How to remove chain from blade no bolts unde cap
If you have removed the bolts that hold the cover, and the chain is still tight on the bar, locate the chain tension screw and turn it to release tension on the chain. The screw drives the pin that fits into the hole on the bar. When you replace the chain, line up the pin and the hole, and ensure the chain is seated in the bar. Tighten the screw until the bar does not move and the chain does not fall off. Adjust to the normal tension for your saw and replace the cover.
Jul 25, 2011 | Poulan 18" Wild Thing Chainsaw
New Rancher 455. Ran for a few minutes then tried to tighten chain but adjuster was maxed out (completely tight clockwise). Removed cover, now can't get tension adjusting pin in hole in bar....pin sits...
Ok.. with the cover off the clutch you notice the screw and the pin that is suppose to go into the hole.. with the chain on the bar back the screw until the pin sits in the hole of the bar.. The chain should be lose you will see the chain dangle at the bottom of the bar.. put the cover back on with it lose.. hand tighten the two nuts that hold the cover on. with the bar in hand and you pulling the bar up make sure the two nuts are on tight enough so the bar does not move but dont over tighten it. tighten the screw you will notice the chain starting to move, and start to tighten up.. once the chain is in the grove of the bar grab the chain and move the chain with your hand to make sure you have not over tighten it. if the chain moves freely and is not lose ( you can also double check how tight it is by grabbing the chain below the bar and letting it go if it snaps back into the bar and doesnt hang there you are where you need to be.) tighten the two nuts up on the cover and start up the saw. Run the saw to make sure everything is all set and nothing is lose before cutting.. If the chain never get to tighten up you need a new chain. buy a new chain and follow the steps again. let me know if you have any questions
Jun 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do you adjust the chain tension on a husqvarna 350 chainsaw ?
I don't own a 360, but most saws you have to loosen the two nuts that hold the bar on, and adjust the adjusting screw that points toward the front of the saw while holding up on the tip of the bar. Tighten until the chain is snug, but still loose enough to be able to spin the chain on the bar.
Dec 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
