Question about GE Nautilus 24" Built-in Dishwasher
GE nautilus wont spray water. I ran it without the water on,think maybe i burned up the pump.
  • 163 Answers
If you ran it for a long time you will need a new pump water keeps it cool and from sezing up
Posted on Jul 26, 2009
Garbage disposal was clogged. now the dishwasher wont get anything clean and wont drain right
clean out the disposal remove lower spray arm and look under plate,also the pump may be dirty or may need to replace so you may need to call repairman,good luck and thanks please un plug before cleaning
Nov 29, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Disheasher not getting any water? Help
If it sounds like its trying to go and not getting any water,, look inside where the dishes go at the bottom for the pump cover.. It should look cup shaped.. The pump could be failing or maybe the valve is just sticking shut - which is pretty common for a machine that has not been used much and sitting..
Whack the pump housing with a wooden spoon - in an attempt to "unstick" the valve..
If that does not help - the valve or pump could be failing..
Good luck..
Sep 16, 2009 | GE Nautilus 24" Built-in Dishwasher
Both Spray arms not spinning
try removing both top and bottom spray arms some just pull off some unscrew,check the holes for any blockages seeds and rice tend to get stuck in them if plates are'nt rinsed properly, place under running tap, hook out with safety pin if neccesary
May 18, 2009 | GE Dishwashers
GE Nautilus making noise
hi you have something in the sump there's a screen on the right side of the spray arm with 2 screws remove them and take screen off use your fingers to probe the cavity be careful it could be glass.
If it does not correct the problem
!.You may have an electric pump . and it could be pump without water . so i would say a bad pump.
I hope this helps...I believe it will....Good luck and good day....thank you for your rating my effort....The Fang.
Mar 23, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher
if the dishwasher has not been used for a few weeks, the water in the sump that goes into the pump will evaporate causing the pump to freeze up. usually you can turn the fins inside the motor to free it up. make sure the dishwasher is not on when you do this.
Dec 05, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus not draining water out
If the pump is not running, it could be the pump or the timing switch. My GSD2600G00WW would not drain. Wash cylce was running fine. I have just taken out the solenoid attached to the pump and the solenoid is burned out. Will replace tomorrow and see if that does the job. On line price for a new solenoid is about $35.00
Oct 16, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
384 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
