Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
My 1991 yamaha t9.9elrp the motor starts good it runs slow at high speed for awhile then goes to high speed some times without moving the throttle this has been going on for 5years (?)
3 Suggested Answers
  • 17 Answers
SOURCE: motor fires off great and run good but at full
i had a similar problem with my merc., turned out to be overheating due to a worn water pump impeller. It would overheat and die, then after it cooled down, would restart. Check to see if you are getting a good stream of water out of the, for lack of a better term, "****", usually located at the bottom of the powerhead, on the rear of the motor. If it\'s just dribbling, dripping, or dry you need a new impeller.
Posted on May 28, 2009
goldbill
  • 184 Answers
SOURCE: running full throttle and on mercury 60HP and it just quit propelling. it will go super slow in forward and it goes in reverse. what has happened?
Maybe the transmission went out. Take the bottom plug from the lower unit and see if it is full of water or lots of metal in the oil. THEN take a magic marker or a punch and hammer and mark the hub of the prop opposite the blades of the prop and go run it again. If the marks move from one another, you need to have the prop repaired.
Posted on Jul 23, 2012
Model ef6600de. How do I decrease rpm?
Search Results
    [PDF]EF4000DE, EF5200DE, EF6600DE, YG4000D ... - Yamaha
    www.yamahamotorsports.com/assets/.../0/LIT-19626-01-15_1425.pdf
    Generator. LIT-19626-01-15. 7WV-28199-11. EF4000DE. EF5200DE. EF6600DE ...This manual will provide you with a good basic understanding of the operation and .....card listing your Yamaha model name, engine ... rpm. NO OTHER ADJUSTMENTS NEEDED. ENGINE OIL: IDLE SPEED: ..... Electric Starting Model:.
    [PDF]yamaha generator theory & diagnostics guide - Gen-Tech
    www.gen-tech.net/fullpanel/uploads/files/theory--diagnostics-guide.pdf
    Yamaha Generator Theory and Diagnostics Guide .... Conventional EF6600DE . ...models with Smart Throttle) do not rely on rpm to ... unit manages functions such as AC power modifica- ... tions means higher fuel economy at lower outputs.
    Yamaha Motor Canada :: Products :: Power Equipment ...
Dec 25, 2015 | Yamaha Electrical Supplies
2008 yardman lawn mower 13.5 hp. has a high idle speed and does not slow down, need diagram for throttle control
Throttle cable should pull a SPRING, which pulls the governor, which pushes/pulls the carburetor butterfly valve.
Aug 12, 2014 | Yard Machines Garden
Anyone k how to set the fuel and air screw on 84try zinger 60cc 3wheeler carberator ?
As long as you know where the air bleed screw is, then do the following; Screw the screw in until it goes no further, (dont force it). Wind the screw out for about 1 and a half turns. Start the motor, you may have to adjust the throttle stop screw t keep the motor running. When the motor is running (at a fairly slow tick over) adjust the air bleed screw outwards a turn or so, if the motor goes faster then your turning the right way, if not, then screw in a bit. What you aim to do is to get the motor running as fast a tickover as possible. When the moto speeds up adjust the throttle stop screw to keep the tickover at a slow speed, It's as easy as that, this setting should be finally made again when the motor has fully warmed up (as the cold start may be in action if the motor is cold).Good luck
Jan 14, 2014 | Motorcycles
Engine cranks up idles good won't accelerate
sounds like a restricted exhaust pipe ,remove the pipe from motor just to see if the motor power returns under throttle if so replace the pipe and gaskets
Dec 30, 2013 | Tusk Yamaha Rhino 660 4x4 Auto 04-07 Oil...
Outboard engine hard to start.
Press the key inwards to activate the Choke. Also, you only pump the bulb when the tank runs dry. Pumping after a successful run, shutdown, pump and restart can flood the engine.
If that doesn't work, claim under the warranty.
specs
Yamaha F20LEHA Outboard Motor Portable
manual, which oddly, doesn't mention a choke feature.
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-17_1378.pdf
Apr 19, 2017 | Boating
Hello. we have just purchased a new Hunter ceiling fan model 20593 with the remote. we installed it and got it working but, it will not go fast at all. we looked at the instruction manual and found that...
It's been awhile so you've probably quit by now, but if yo haven't , try this: Get up into the light bowl area nad look for the pull chain on the side of the housing. Pull it 2 times and it should put the motor into high speed. Click the #3 on the remote and see if it goes to high speed. If not, pull the chain and try again. Keep doing this until the motor gets into high speed. It should only take a few times at most.
May 23, 2011 | Kitchen Ranges
2008 Yamaha Zuma Idle Speed Problems This is a stock 2008 Zuma 50cc scooter with 2200 miles on it that has a high speed surging issue. I can't get this to idle properly. When cold the engine starts...
TRY THIS;WHILE RUNNING SPRAY WD40 ALL OVER ENGINE..MOVE SLOWLY WHILE SPRAYING..NOW IF ENGINE REVS UP MAJIOR VACUMM LEAK....FIX AND BE HAPPY..GOOD LUCK..INDIAN HEAD SHALAC IS THE BEST SEALANT FOR ALL GASKETS AND VERY CHEAP COMPARED TO OTHERS THAT FAIL AFTER GETTING HOT A COUPLE OF TIMES..BUT I WOULD SAY YOU HAVE SOME KIND OF LEAK..THE ENGINE WILL BE SUCKING ALOT OF AIR THRU THIS AREA.PLUS IF IT LOOKS WET AROUND GASKET OR OIL LEAKS FAILING GASKETS..POTENTAIL VACUMM AREA..HOW DID IT RUN AFTER REBUILT..COULD BE SHOTTY WORK..JUST EXPLORING ALL AVENUES..COULD NEED HEAD RETORQUE IF THEY DIDNT USE LOCK TITE..BLUE NEVER THE RED..RED IS PERMANTE NEVER COMMING APART..HOPE THIS HELPS..BUT IF THE WORK YOU HAD DONE IS STILL UNDER WARRANTY THAN GIVE IT BACK TO GET FIXED..
May 21, 2011 | 2008 Yamaha Zuma
How far does the high and low screw need to be unscrewed or screwed in on the carburetor. of the chair saw
The position of the screws is set while the motor is running, The screw nearest the cylinder is the low speed adjustment and the other is the high speed adjustment. Start the engine and adjust the slow screw till the motor idles smoothly without wanting to cut out. Then open the throttle and adjust the other screw till the engine runs at a good, steady speed without over revving. If the setting of the screws has been totally upset, start with the screws about 2 turns out from the stop and work from there until it starts and runs, then you can set the optimal running settings.
Mar 26, 2011 | Garden
Need intructions on carberator adjustments for mac-3514 35cc/cm3 runs but hard to start after using it for few minutes.
There is a low speed jet and high speed. Low speed sets the idle or stays running without feathering the throttle./// When setting high speed, hold the throttle wide open until engine revs high, then turn back in(at least ΒΌ turn) to slow the engine which in turn gives the engine more gas and runs cooler. If you have it too lean on the high speed, it will be hot and hard to start. Sometimes using 40 to 1 mix helps with starting, especially on older chainsaw. good luck
Sep 22, 2010 | McCulloch Garden
2006 yamaha rhino 450 cuts out at high speed 30mph used to get almost 40. Has after market cdi kn air filter rejetted 2 richer. runs great slow to mid range even full throttle in sand is good...just high...
I would double check compatibility and wiring hook-up of the A/M CDI. See if the previous jets (if undamaged) improve top end. The leaner, the meaner!
Apr 21, 2010 | Yamaha WR 450 F Motorcycles
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
32 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
