Question about Home
I have this problem with this mettler toledo scale:
Zero failure weight outside power up zero limit. add/remove weight sw18
mhkamran
  • 180 Answers
SOURCE: PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Posted on Aug 18, 2009
SOURCE: How do you zero out a health o meter weight tracking scale?
After stepping on the scale to Activate your number (1-4), hold it down and it will say "reset" or (something to that effect), then Yes, or tap it once and it will say "no". If you want to reset, when it says "Yes", continue to hold it down, and it will then reset to zero.
Posted on Jan 27, 2010
ankitchandel
  • 141 Answers
SOURCE: my scale is reading 4.4
you have a reset button on your scale so tab this button.
Posted on Feb 18, 2011
SOURCE: I need calibration instruction for Mettler Toledo
I WANT TO CALIBRATE METTLER TOLEDO IND - 690.. PLEASE ME..TEACH ME HOW
Posted on May 29, 2011
  • 3247 Answers
SOURCE: mettler toledo manuals
Without a model number it is hard to find the manuals.
But if you visit this site and type the model number you might get whatever you are after.
Document Finder
Posted on Sep 05, 2014
What does the triple e error code on a Mettler Toledo scale
ive seen this before on my scale (don't know your model number??), seems the cable to the bottom platform was damaged , the guy said it was reading disconnected . ?? he replaced the entire lower part and it worked well again , found out later my temp hit it with a pallet lift , so that's how it got damaged .
Feb 02, 2017 | Mettler Health & Beauty
Manual for mettler P1210N
Where can I find manual for Mettler P1210N top loading balance
Dec 29, 2013 | Mettler Toledo Mettler P1210 Balance Scale...
My scale adds anywhere from 5 lbs to 35 lbs to my family's weight. I just had my daughter weighed yesterday and this scale added 5 lbs and when my husband or I get on it, it adds anywhere from 30 to 35 lbs...
there should be a dial on the sides to zero it out. if it doesnt, then it has something to do on the actual scale. does it have a menu or settings option? you should be able to zero it out.
Dec 10, 2010 | Homedics Glass Digital Scale - Advanced...
I need an owners manual for a toledo scale 4662ex 20lb capacity
http://us.mt.com/us/en/home/search/Download_Center.html
This link will allow you to type in your model number, and download the literature available.
You can also call 1 800 METTLER if the website is too slow, and they should be able to transfer you to someone that can email it too you. I hope this helps, good luck!
Nov 23, 2010 | Garden
ERR12 AND16 KEEP COMMING UP NEW SCALES unable to reset
Err 12 Inital load is too high power on zero point outside permissible range
Err 16 No zero point available, unable to calculate weight
Check no load on platform
Check the sensor this could be defective. This is the most likely
Sep 02, 2010 | Seca 354 Digital Baby Scale Pediatric...
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
I need calibration instruction for Mettler Toledo IND690 and ID3sTx, please
Oct 21, 2009 | Zebra Printer 140-751-00000
I have an old toledo electronic scale that I need to reset? This is an old electronic scale and it is flashing 0000. The name on the machine is Toledo Sentinel III model 8420
To Whom It May Concern:
I have access to the same model you mention in your post. It was handed to me for repair and I did my best to track down a schematic for Toledo Scale model 8420. Coincidentally I happen to work in the same neighborhood that Mettler-Toledo is located and getting to their CSR was easy. Bad news is this same CSR who is what we in the industry call a "Lifer" didn't have any of the service documentation for this 25+ year-old scale.
Good news is I made a request to the original owner not to throw out the scale once I returned it. If you are interested in buying the scale "as-is" and salvaging the parts needed to solve your reset and 0000 problem, this may be your best opportunity. I don't know as of this writing what the original owner, a restaurateur, will ask for the scale but estimate it won't be much. These scales are industrial strength and this particular one is in great cosmetic condition.
Because I am new to Fixya and don't have the patience to set up an account presently, you will have to post your reply as you did for your initial question. I will check the site in a couple of days to see what has transpired and go from there.
Best regards,
Chris
Oct 19, 2009 | Kitchen Appliances - Others
Home Logo
359 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
