Question about Garden
My pto belt on my 1987 wheel horse keeps twisting before the pto. I have the two pulleys on the front set as wide pully on the outside. Is this correct. Their are two spacers not sure were they go
SOURCE: Neptune MAH3000AWW Pullys dont line up
Found that the rear bearing was bad, did not want to spend big money on very old machine so just replaced it.
Posted on Feb 28, 2009
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
  • 1111 Answers
SOURCE: G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Posted on Aug 07, 2009
ftw1952
  • 10319 Answers
SOURCE: Honda harmony 1011 - hydrostatic
is the belt very old? if so it is stretched and needs to be replaced. All belts with a heavy fabric woven around the belt averages a 5 year life span
If it is a simple rubber/nylon corded belt one year is its life span
Posted on Jun 05, 2011
How to change pto belt on club cadet 1046
To replace a transmission drive belt on a Cub Cadet LT1046 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ) You need a 5/8" socket to get the bolt out of the PTO pulley assy.(electric clutch). If you don't have an impact wrench take a spark plug out and push rope into the hole. This will bind the cylinder and keep the drive shaft from turning. Remove rope and replace plug when finished. Battery and/or spark plug wires should be removed for this process for safety.
The PTO may be stuck on there so you may want to tap it with a hammer and a block of wood carefully to release it. Loosen old belt from tensioner pulley. Lower engine pully on drive shaft, below pully "keys". It may be difficult to remove. Spray with "PB Blaster" or similar bolt loosener spray. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, make a diagram to help.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO pulley is "keyed" on the shaft. Replace bolt and washer. Torque bolt to 38-50 ft. lbs. using the rope meathod as described before. Put your deck back on and you're ready to mow again
May 11, 2017 | Garden
Drive belt keeps twisting and coming off pulleys
Could be the pully are not inline, this would throw the belt when you engage the drive. Could be the wrong belt fitted. Could be wrong tension setting. The twisting element could be that the belt is damaged or incorrectly tensioned.
Many operators consider changing from V belts to Toothed belts because there is less squealing, better efficiency and far fewer disengaging problems
Mar 17, 2015 | Garden
Hi, got a new belt for my candy CM1 166/1 washing machine but it keeps coming off , its the correct belt , the pulley wheel does not have any play and hardly any on motor wheel either ,belt keeps going...
If the belt is coming off the pullies my be out of line .you need to put a straight edge across the two pullies to make sure they are level . And check there's enough tension on the belt .
Nov 07, 2014 | Washing Machines
I have a Husky YTH1542XP and am having a problem with the motion belt. I had to replace the mower belt, no problem..I figured I would replace the motion belt also it in bad shape. Following the...
This procedure should be performed with the deck removed. Removal of the PTO clutch and engine pulley should be step one. The crank bolt is 5/8ths. Be sure to unplug the clutch before you remove the bolt. Plug is at hole in chasis on right side rear of engine compartment. Lock brake. Drop the clutch and engine pulley, remove belt from engine pulley then from transaxle pulley. Remove belt from idler pulleys. Istallation is reverse of removal. Be sure the PTO clutch is seated in its retainer ( a bracket that comes down from the chassis and fits into a notch on the PTO clutch. This keeps the clutch from spinning around when engaged. It will rip the wires out if not secured properly). If you bent any belt guides to get the belt off without removing the engine pulley be sure to bend them back.
Nov 21, 2012 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Belt systme view - how all belts are hooked up
you have 2 pulleys going to the blades, 1 pulley coming from the pto, and a belt tensioner. the belt goes on the outside of the pto, outside left side blade, inside belt tensioner, out side right side blade.
Aug 16, 2009 | Ariens 34 In. Zoom Series Riding Mower
Belt jumped off pullies
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
Apr 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Show me how the belt should be run
Stick the idler in the floorboard, even with the motor pulley and have the idler wheel facing to the left of that motor pulley. Insert the non twisted belt into the idler between the cheapass metal idler pulley mount(have yer woman hold that drum up, make her proud to assist) and now yank back on the idler good nuff to get that belt looped over that motor pully. Then let that idler go so the tenshun on dat boy cause dat belt to stay all propah on dat pulley. Replace that front panel. 05cc3f4.jpg
Belt config
Feb 26, 2009 | Kenmore 62802 Electric Dryer
Need the belt diagram for the water pump belt for a 95 Auroa
42161874BELT, REPLACE
  1. Release belt tension and remove belt from power steering and alternator pulleys. Twist belt to get between tensioner and front cover and between power steering pulley and engine mount bracket.
  2. Raise and support vehicle.
  3. Turn wheel to the extreme right and remove right side splash shield.
  4. Remove belt from crankshaft and A/C compressor pulleys. Twist belt to get between idler pulley and engine mount bracket.
  5. Lower vehicle.
  6. Twisting new belt to get past the front cover, install belt around power steering pump pulley, Fig. 15. Allow belt to hang free.
  7. Twist belt to get between tensioner and front cover, wrap belt around alternator.
  8. Remove belt from power steering pulley and set aside.
  9. Raise and support vehicle, then twist belt to get between tensioner and front cover, wrap belt around crankshaft and A/C compressor pulleys.
  10. Install right side splash shield and lower vehicle.
  11. Position belt around power steering pulley and release tensioner.
Nov 23, 2008 | 1995 Oldsmobile Aurora
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
