Question about Ricoh Office Equipment & Supplies
Our RICOH 2050 Copier-Printer [On the network] keeps coming up with a red error screen at the end of a job and says Functional Problem Detected???? why???
    New Friend:
  • Ricoh Expert
  • 164 Answers
What's is code will tell us problem with copier
Posted on May 03, 2017
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
The Ricoh Mp 2000 copier displays "Error occured Sc:545 Functional problem"
It's a fuser overheat error enter service mode to clear, if it comes back service call ( push in sequence clear modes(yellow) 1 0 7 hold down stop for 5 or so seconds, screen will change, power down, red switch. -Carl
Jan 30, 2014 | Ricoh Aficio MP 2000 Black and White...
What is problem with my Ricoh aficio 2018D when i can read on screen error 553 ?
fuser problem, push in order clear modes (yellow button) 1 0 7 and hold the red stop button for 5 seconds the screen will change, turn off copier red power switch and turn back on if problem comes right back you need a service call
Sep 27, 2013 | Ricoh Aficio 2018D All-In-One Laser...
I do not know how may I repair error sc 546 in ricoh aficio ap410n
Sep 25, 2013 | Ricoh Aficio AP410N Laser Printer
I have a ricoh 1224, and is displaying a 'functional problems' notice. Is there a solution to solve this?
What is the exact error code that you are getting? There should be a code displayed on the screen, starting with "SC" and ending with three numbers. Those three numbers will determine what the exact problem is. Depending on the code, it may be something easily fixable, but if it requires replacement of any parts, you may be out of luck -- the 1224 is an old printer, and it may be difficult to find new parts for it.
Aug 18, 2011 | Ricoh Aficio 450 Copier
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
Aug 03, 2009 | Ricoh Aficio AP410N Laser Printer
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
