Question about RCA Computers & Internet
Rca tablet Will not boot
How do u factory reset my RCA tablet
well, i don't know what model tablet you use.
but generally you can do hard reset by this way:
1. off the tablet
2. with tablet is off, press and hold volume + (up) button and power button. release both of button when you see boot screen.
3. use volume up/down to scroll the menu, scroll to highlight "Wipe Data/Factory Reset".
4. press power button to select
5. scroll to highlight "Yes -- delete all user data" and press power button to confirm and wait until done
6. select reboot now when finish
just google RCA tablet hard reset for more detail explanation. good luck
Sep 27, 2017 | Tablets & eReaders
Who do i contact for a warranty?
It depends on where you live. You could try to take it back to the store you bought it from, or check directly with RCA. Click here... RCA Support RCA Made For Moments
Mar 29, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
With the charger hooked up and plugged in the tablet will only show the battery on the screen briefly to let you know it's charging. It won't actually boot up until it has a sufficient charge. Just let it set that way for a couple of hours then try to power up.
Feb 26, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
Why does my RCA tablet turn on but not boot up? Just says RCA on screen and will not advance.
See this site...
Jul 03, 2014 | Tablets & eReaders
My tablet is on Safe mode and dont know what or where to go or do to get it back normal operating mode rca 7inch tablet model rct
The only way is to hook it up to computer and boot with software it came with. Or you can download it from website. Since it could mean possible hardware failure. Either by water or moisture
Jun 23, 2014 | RCA Tablets & eReaders
Rca tablet will not boot
Here are some common reasons tablets wont boot:
- SD card full or corrupted
Remove SD card (if you have one in your tablet) and try to boot
- Corrupted OS / Application / Data
Try a reset
If your tablet is rooted, you can often boot with the bootloader and wipe the application data.
re-flashing the firmware of the tablet works 99% of the time.
Jan 30, 2014 | Tablets & eReaders
Reset rca tablet
You can perform a hard reset on your tablet 2 ways. The first is by going into Settings>backup and reset and choosing the Factory Data Reset option.
If you are stuck at the startup screen or a password/pattern screen and cannot boot into the system, you will need to use method 2, which is booting into recovery mode. Have the tablet powered off first and make sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should next see an android image. Press and hold the power button and tap the volume up button once more and you will be brought to the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet will be set to factory original settings.
Jan 12, 2014 | Tablets & eReaders
Computers & Internet Logo
Top RCA Computers & Internet Experts
Julie Endres
David Payne
David Payne
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
