Spin circle not working - Washing Machines
MY SKY ROVER HELICOPTER TAIL SPIND A CIRCLE
the trim is out of line, for the love of god watch some beginners videos on setup.
Mar 26, 2016 | WowToyz IN-EZRU Propeller Powered Giant...
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
What spin number shud it be on
its not a number,, its a round circle symbol.. there are 2,, 1 is a half spin,, and the other is a full spin
Oct 19, 2012 | Hotpoint WMA64 Front Load Washer
My ps3 controller has a r2 rapid fire mod in it and now the right analog stick just makes my mw2 character spin in circles what can i do?
Push down on the top of the knob,like the R3 button on PS2,not down directional,and spin it in circles at the same time.I just basically go spastic on my controller for about 5 second bursts and it always gets rid of the spin.Your R2 may be stuck too.Push on it real fast a few times and it should unlock.If the R2 does not stop,you probably need a new controller. :(
Good luck and game on!
Jul 25, 2010 | Sony Dual Shock 3 Controller for...
Vestax PDX 2000 motor going crazy problem
hey, it will work with the tape solution but you gotta pay attention to the light metallic circle which is used by the light sensor (the small black one with cables on it) to estimate motor movement - first time i opened it and did the tape thing to the black rubber circle i eventually touched the light metallic circle and i think that caused it not working for me too
the light metallic circle must be totally clean and plain, do your best, but be sensible
Jul 09, 2010 | Vestax Pdx2000 Direct Drive Turntable...
I just got a refurbished xbox 360 elite and when i turn the wireless controller on it doesn't connect. It just keeps blinking. How do i get it to connect?
To begin, turn on your xbox 360. On the top of the wireless controller, to the right of the LB button there is a small white button. Hold this, and the lights near the xbox button will spin in a circle. On the front of your xbox 360, there is a button to right of the memory card slot. Press this button and the lights on the front of the xbox will spin. After a few seconds, the controller should synch with the xbox. If this does not work, make sure that the lights are spinning in circles at the same time.
Please let me know if you need any more help
Jun 13, 2010 | Microsoft Xbox 360 Console
Won't hardly spin
the back and fourth motion is normal. we have a ge and it does the same thing. for the slow spin and burt rubber smell the drive belt is more than likely streched, the fast fix is to replace the belt. HOPE IT WORKS FOR YOU!
Feb 12, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
