Instructions for NA386 remote as mine doesn't work except for on/off button
    Sergeant:
    Champion:
  • 247 Answers
Check battery? ck clean ir eye with window cleaner, clean surface of the remote. lol.
Posted on Apr 26, 2017
Reset lamp timer
Simple answer: -vol button on set and split button on remote hold at the same time
I just figured mine out!!!! So many people with so many different solutions. I read the instructions for the TV, those says to read the instructions for the lamp. I read the instructions for the lamp but this model isn't on the instruction list. For other models it says to use the volume down button on the set and the PIP on the remote. No PIP button on the remote. But wait the bottom row of buttons has a multifunction button for split screen! I tried that and it worked. I had a message that said the lamp timer was set to zero. Done! Hope this helps someone out there.
Feb 09, 2014 | Panasonic PT-61LCX65 61" Rear Projection...
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
I have a remote oneforall i need codes for a SHARP VCR please help need codes
There are two codes for Sharp. You'll have to try both to see which one works. 0048 & 0807. I am assuming you don't have a manual.
On the remote press and release the VCR/DVD button. Press and hold the SET button until the LED blinks twice. (it will blink once when you first press it, that doesn't count.) Just wait a few seconds. After it blinks twice, release the SET botton, and enter the CODE..
The LED should blink twice. Aim the remote at your VCR and press
POWER.. The VCR should turn on. If not, try the other code.
0048 worked on mine. Good Luck!
Aug 15, 2011 | Universal Remote Control Remote Control
I have an rca universal remote without a code search button. i want to program it to a toshiba tv but can't. how do i program it?
You can try going to the RCA website and looking up the user manual for your model of universal remote. I happened to need to do that today for mine which also has no code search button. I found out that mine is a model RCR412BN. I was able to find the user instructions on how to set the codes for my TV, DVD and Digital converter by following these instructions on the RCA website ... worked great!
This is the model I have ..... http://www.rcaaccessories.com/universalremotes/?sku=RCR412BN
and here's the user manual online ... http://audiovox2.info/docs/rca_acc/man/RCR412BN_DOC_OM.PDF
Aug 16, 2010 | RCA Universal Remote Control
I have a Dish Network 20.0 IR remote. How do I program it to work with my Haier TV?
duckie715
We don't have any codes available for your Haier TV, however, I have provided instructions on how to perform a power scan to locate a code the operate your TV.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Address To Other Equipment Using Power Scan
  • Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button (SAT) until all mode button backlights illuminate, then release.
    2. Press and release the Power button.
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Oct 04, 2009 | DISH Network IR Remote Control
Lost instruction book for universal remote
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
Apr 25, 2009 | Philips Magnavox MRU1400 Universal remote...
''1992 Cadillac DeVille keyless entry doesn t always work''
your vallet button is pushed mine is in thhe glove box turn it off i thought i needed a battery 2 good luck
Mar 19, 2009 | 1992 Cadillac DeVille
Trying to find programming instructions and codes.
Ok I just got a new universal remote so I have a paper with all the codes. For the Brooksonic the code is 0932 and to program it press the set up button on the top of the remote, then press either the TV, DVD, or VCR button (which ever one you want to use) and then enter the code in. It should work, but I have been trying to program mine for a while now and I cant get it to work, so if anyone can help me out that would be great. I have the code to mine and the instructions, I just cant get it to work!
Mar 19, 2009 | GE JASRM24912 Remote Control
Screen is blank with sound working
i just fixed mine by doing this. on the remote there should be a button that says f. hold down the f button then press mute and that should work it did for me
Apr 02, 2007 | Polaroid TTM-2003 Combo
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
