Question about Staples Tools & Hardware - Others
After ejecting five staples, my staple gun stopped pulling staples into the feed and ejecting them. It makes the shooting sound, but nothing comes out. I examined it for staple jam, but found nothing.
    Sergeant:
    Champion:
  • 247 Answers
Staple guns are feed from the rear by a spring. check and see that the spring is still douing its job. if this isa air feed,inpact gunn, clean ejector ports and staple slide.
Posted on Apr 26, 2017
My gun will not shoot staples
The most common cause of the gun not firing is loading it with the wrong staples. Look at the packaging for the staples and see if it lists the gun. Staples are NOT universal and are make for specific staple guns.
It "sounds like" it is jammed. You may have to pull out the staple with needle nosed pliers. e`1
How to Load Staple Gun
How to Troubleshoot Staple Gun Hunker
Oct 04, 2017 | Staples Tools & Hardware - Others
My gun fires four or five staples all a once--is there an adjustment. with shooting so many staples at once then they do not go in all the way
  • This may or may not help, but I have one that was doing the same (as many as five at one trigger pull). I gave it the little WD40 and it still did the same. Then, I thought maybe it was the effect of not being used for a while. I proceeded to pull the trigger several hundred times (you can do this without staples loaded) and now, mine works fine. Seems to have helped.
Sep 16, 2014 | Electric Stanley Tre500 Staple Gun /...
Electric tacker shoots, staples do not eject
jl open up the slide ,there is a spring end that pushes the staples into the head ,that sticks in the rail a small screwdriver will release it,it will get stuck again but now you know the prob.
Jan 07, 2013 | Duo Fast Duofast Carpet Pro Electric...
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
Apr 26, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
Stanley light duty staple gun loads and shoots but staples not coming out. nothing jammed as far as I can see. Should I open it up and have a look at the interior? Thank you Denise
It sounds to me like you must have a staple that has seperated and probablygot stuck in staple feed shute' I wouold carefuflly remove side plate and see if there is a staple in there crooked or if their is is small metal chip left over from manufacture.I hope this helps you.THANK.
Apr 07, 2011 | Stanley TR40 Light Duty Tacker
Stapler will staple ok then it will jamb and break staple in half,and driver will stick but you can put driver back and will run for a short time then has same problem. It also is breaking up staples as it...
It sounds like the gun is working properly but is having feeding problems. First, make sure you are using the proper staples for your gun. Senco makes three versions of the SKS(XP) stapler: The SKS L11-17 drives 18 gauge, 1/4" staples. The SKS M12-17 drives 18 gauge, 3/8" staples. The SKS N12-17 drives 16 guage, 7/16" staples. None of them use staples over 1 1/2" long and each gun will only shoot the staples it is set up for. If you are using the correct staples make sure the rail and nose peices are clean and the feeder shoe and staples are riding freely on the rail and the feeder spring holds them firmly forward in the gun. Lastly check the tip of the driver to make sure it is square, it should not be rounded or have any chips out of it.
Dec 07, 2010 | Senco SKS 18 Gauge Stapler
My etfx50 arrow staple gun jams, what can I do to fix this problem?
There is a screw and nut at the feeding end of the gun that allows you to remove the guide and get to the jam. Make sure it is unplugged and prepare for the firing mechanism to eject the jammed staple. Otherwise, a pretty simple maneuver. Wish Arrow would have included such in their owner's manual.
Nov 30, 2010 | Aerobie Arrow Etfx50 Staple Nail Gun
Arrow staple gun will not shoot it seems it is locked into place
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Nov 23, 2010 | Arrow T50P ARROW STAPLE GUN
Won't shoot staples it still shoots no staples come out was working fine seconds before
look for a jammed staple near the end of the magazine that is stopping them from advancing. Also make sure they move freely in/on the magazine. Double check to ensure that you are using the right staples for this tool.
Sep 28, 2009 | Ace Hardware Tools & Hardware - Others
T50 stapler gun it worked for about 15 applications then just stopped, it's not jammed, it has staples loaded properly & firing off staples repeatedly doesn't work nothing comes out??? Why would it just...
It sounds like a manufactor defect in wire harness or premature silinoid burn out,
or you simply need to make sure you plug into and outlet that works. Could be cheap but not worth repair,return as defect if possiable and buy new one before.
Please rate. Thanks jj505
Mar 27, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Tools & Hardware - Others Logo
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
