TV turns on but can't see anything until I put a flash light to it then I can barely see that it is on
I have a Hitachi LE42H508 tv that has an extremely dim picture. I have to turn the lights off to barely see anything on it. Sounds works great and I can navigate the menu and all fine. I can just barley...
Look thru the set up menu and see if there is an ambient light setting that adjusts the brightness of the TV based on the light level in the room. If there is then turn it off.
Nov 19, 2017 | Hitachi Televison & Video
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
I smelled something electrical overheating or burning...I've smelled it before late at night. The 40-incher was going for about 8 to 10 hours now and I looked inside the body of the TV and saw a red light...
Now the tv u turn on?Ur tv now,have no power to the tv at all or the tv have a red or green LED power light indication is flashing only?Yes,than the tv power supply board is the causes and the problems.That the tv board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 22, 2011 | Sony BRAVIA KDL52XBR2 Television
Cant calibrate tony hawk shred board to my wii. I've tried everything
At last! My Son's Tony Hawk Shred board was one more try from being thown down the garden, as i have been trying since Christmas day, & finally there it was a board i could use. I've followed all bits of advice in a number of differant ways --- here's what worked for me, Turn off at the wall Sky TV, Turn off all lights (only tv turned on), put my crutches in another room (because large metal objects interfere with soft ware), Remove dog from room, Put senser bar on floor, Turn Wii console side on so that Dongle faced away from tv (aiming into centre of room), Place Shred board on floor facing tv/senser at about three feet away. Start process of game set up untill you get to choose a profile, Select profile, press & hold for 5 secs start button on board untill the four blue lights start to flash at a rate of about one flash per sec, then hold on same button untill blue lights flash quickly, then press & hold Dongle button untill Dongle light stays on, with in 2 secs game calibartion instructions start, BEWARE Tony Hawks responce when process starts is as annoying as not being able to get board started. Good luck when up & running it is one Awesome game!
Jan 01, 2011 | Activision Tony Hawk Ride for Nintendo Wii
Samsung DLP HLN617W TV does not turn on, all 3 lights flash
In this case it seems you may have an issue with your ballast. Either it's going out or barely starting. I recommend you replace it
Aug 06, 2009 | Samsung Televison & Video
I just replaced the bulb on my sony rear projection tv
THE CODE FOR 6 RED FLASHES IS YOUR THERMAL FUSE ITS LOCATED ON YOUR FAN HOUSEING FOR YOUR LAMP WHEN YOU FIND THE FUSE USE A JUMPER OR JUST TWIST THE BARE WIRES FOR THE FUSE TOGETHER AND TRY TO START THE T.V. TO CHECK IF THE FUSE IS GOOD ITS A LITTLE BLACK SQUARE LOOKING PIECE
Mar 08, 2009 | Televison & Video
I have a Rogers HD cable box and want to control my Soyo HDTV with it. I look in the Rogers manual but could not locate the device code. Can you tell me what it might be?
first you have to know witch remote you have there is a 3 button witch has vcr tv and cbl at the top that one there press tv and select at the same time untill the light flashes 3 times release then enter 9-9-1 the pres the tv button untill the tv turns off if you have the newest 5 button remote you will press tv release press and hold setup untill light flash's 3 times then enter 9-9-1 light will flash once entered then press ch+ sevral times untill your tv turns off once tv turns off stop and press setup and that will lock the code inplace i hope that helps
Nov 24, 2008 | Soyo DYLT032D 32 in. LCD Television
Technika tt- 706 universal 2 in 1 remote
turn the tv on. hold tv and set buttons untill the power button flashes. point the remot at the tv untill the tv turns its self off. press any button on the remote. turn the tv back on and test it.
Oct 10, 2007 | Televison & Video
Tv will not turn on--- flashing red led
I'm sorry, I don't have a solution, but I seem to be having a similar problem. When I turn my TV on, the green light comes on like it's powered up, but then the TV turns itself back off and the red LED light flashes. I can't do anything to turn it on or anything.
Jul 11, 2007 | Philips 37FD9954 37 in. HD-Ready Plasma...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
