Question about Cub Cadet Garden
Cub Cadet will not start Has gas,oil,spark and fuel is pumping to carb
  • Jeff
    Jeff Apr 26, 2017
    Yes I have and yes good spark on both plugs
  • yadayada
    yadayada Apr 26, 2017
    Get a spray can of starter fluid (a few dollars) and spray it in the Air intake to the engine se if it starts.
    Top Expert:
  • Cub Cadet Master
  • 79,851 Answers
Have you checked for spark at the spark plug, do that and report back.
Posted on Apr 26, 2017
IHAVE A CUB CADET 173CCOHV SELF PROPELED WON'T START NEW PLUG GAS TO THE CARB OK OK AIR FILTER OK CLEANED CARB STILL WON'T START.
got to have fuel, spark, air and compression. your missing one. be sure plug is good. give it a shot of carburetor cleaner. if it starts and dies it is fuel. check compression. take off valve cover and be sure valves are working as they should and gaped correctly.
Oct 24, 2016 | Cub Cadet Garden
Cub cadet 1000 series
Fuel pump if it has one, gas shutoff valve if it has one, or maybe just the float valve inside the carburetor bowl is stuck closed.
Jul 31, 2014 | Cub Cadet Garden
Will start but want stay running gas with oil was put in mower
rebuild carb and clean thje holes in carb with compressed air to get oil out of it clean fuel tank change filter blow out fuel pump with compressdair
Apr 15, 2014 | Cub Cadet Garden
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
2008 Cub Cadet LT1042 Won't Start
If there is a fuel cup on the bottom of the carb take it off and clean it out real good. Take the fuel jet out and clean out the little hole by blowing it with air compressor or a real fine wire.The fuel jet is most likely the problem.
Jun 21, 2017 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet that wont stay running.
Is the gas more than 5 months old? If so drain the old gas and replace with fresh gas.
If that does not fix it try replacing the fuel filter.
If that doesnt fix it try cleaning and re-gapping the spark plug or replace the spark plug. If none of these easy fixes do it then it could be a dirty carb.
Apr 04, 2010 | Garden
Garden Logo
43 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
