I have keyboard and mouse does not work and usb port too
My package bell mv 305 have the same problem.. keyboard and mouse internal does not working and usb does not work too..
How I can solve the problem?
the windows system can acces and startup but I can not log on into system because I set user account.
How I can log in if the keyb and mouse did not work..
If i release the windows.. I can not log into setup system by press F2 with internal and usb keyboard?
I am dead in mind????
    Sergeant:
    Novelist:
  • 192 Answers
Does the keyboard respond upon system boot. It should.
Press F8 repeatedly until you come to a black screen with text and select command line with safe mode or command line depending on the type of operating system you have.
If it is Windows XP, type in the command prompt: c:\windows\system32\restore\rstrui.exe and restore windows to a time when it was working properly.
If it is Windows Vista, type c:\windows\system32\rstrui.exe.
Posted on Jul 25, 2009
Team promark keyboard won't work
If it has a USB plug, try attaching it through a different port hub, i.e. not the usb port right next to the one that didn't work. If that doesn't work, test the usb port with something else first. If the USB port is not the problem, you may need to download a driver for the keyboard.
Jan 03, 2012 | Team International Team ProMark Carolina...
Intel d 865 gsa mother board is working but not display no beep what is the problem
i thinks it's not working, check again.....
no display, no beep.....simple symptom of a dead MB
the quality of the MB is all components will work together, even if one component in it fails the MB is dead.....
this rule is not applicable to the following devices in the MB
inbuilt sound cards, or
either of the USB ports or
mouse port, keyboard port
As you can use an external device like a USB sound adaptor insted of the internal sound card for your speaker/sound.
The same goes for mouse and keyboard, you can buy keyboards/mouse that work thru USB
The same is of a USB port, if one of the USB ports fail you have the other ports to use, if all of the USB ports fail then you can use a external USB connector to a LAN port and make the LAN port a USB device.
also.....there is no option..... that you can change one of the components.....they all are embeded in the circuit board, it's cost effective to get a new MB than repair the defective component.....
all the best
Nov 18, 2010 | Intel Motherboard
Computer does not recognize the keyboard,, have windows xp 2002 sp3, and bot the USB keyboard/mouse from crayola. another keyboard that is USB works just fine, so not the port???
Sakar International makes this product.
According to them, your operating system isn't supported, although for the life of me I cannot see why.
Here are the supported operating systems:
System Requirements: --Windows 98SE, ME, 2000, XP or Vista --Mac OS X (10.1 or higher) --One available USB port
Here is the website for the mouse:
http://www.sakar.com/p-1602.aspx?return=y&txt=crayola&page=0
And here is the website for the keyboard:
http://www.sakar.com/p-1600.aspx?return=y&txt=crayola&page=0
I'm sorry I couldnt help more. This should be resolveable, but the company has no information on how to resolve it.
Oct 28, 2010 | Crayola Keyboard w Mouse and Mouse Pad...
My Acer KU 0760 keyboard is not working at all. Seem as if the computer doesn't recognize it at all. The mouse works in the USB ports, but nothing from the keyboard. Had old gatway keyboard laying...
Try the keyboard in the USB port you've been using for your mouse. Just move your mouse to a different USB port. I know, this seems like a "too simple" solution, but USB ports sometime get cranky.
A question I would have would be: have you been using a PS2-type keyboard prior to trying to use the Acer USB one? Sometimes the BIOS needs the item "use USB port for keyboard" turned on.
Oct 26, 2010 | Acer NSK8458AN Keyboard
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
USB and Mouse/keyboard ports dont work
You can buy adapter from newegg.com to convert standard PC mini-din keyboards/mouse to USB.
Oct 27, 2009 | Biostar TFORCE 6100 Motherboard
The wireless mouse and keyboard are no longer working on my computer--i've put the adapters in every usb port on my desktopa and ALL ports are not working...the adapters will however, work just fine when...
go onto the desktops manafacturors website and download a new USB driver and it might work or go into controle panel and go add hardware in mouses and other devices and try to re-install the adapters
Sep 02, 2009 | Microsoft Wireless Notebook Optical Mouse...
USB ports don't work
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
khandan10
Apr 02, 2009 | ASUS P4XP-X Motherboard
Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Dec 07, 2008 | Foxconn 6100K8MA-RS Motherboard
Keyboard intermittent
There might be a problem with the keyboards PS2 port. You can bypass the PS2 port all together by buying a PS2 Y-adapter to usb port. This Y adapter will allow you to plug your PS2 mouse & keyboard into it and than you plug the other end into a free usb port. You do not have to plug the PS2 mouse in if you do not want to. Just plug in the keyboard. If your keyboard functions than there is a prolem with the keyboard's PS2 port. The PS2 Y-adapter to USB runs about $12.00 to $15.00. You can find one at Wallmart.
Jan 07, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
