Question about Coffee Makers & Espresso Machines
After cleaning cycle, tablet was found in tray
    Genius:
  • 2,500 Answers
Pick it up if you still want it.
Good luck
Mai
Posted on Apr 26, 2017
We have a Kenwood dishwasher and last week found some water in the base after a cleaning cycle. We cleaned the filter than ran the dishwasher cycle with a cleaning tablet which seemed to fix the problem....
sounds like the pump intake maybe stopped up or the pump is worn out, with the dishes not getting clean this sounds like a pressure problem
Jan 29, 2014 | Dishwashers
Dishwasher does not clean dishes. Some soap remains in soap dish. Have tried on the enrgy saver cycle and 1 hour cycle.
Hi jerry1413,
Firstly, make sure you are using powdered soap, and not the 3 in 1 tablets. The 3 in 1 Tablets only release certain parts of itself on certain temperatures, and because all dishwashers aren't alike, they won't have the best of results on all makes & models. Cycles aren't run the same way on every Make, and don't follow the same order either. Trust Me ;-) , stick to Powder.
Furthermore, check the following link for some advice and suggestions on getting your dishwasher to clean properly again:
WHAT TO DO IF YOUR DISHWASHER ISN'T CLEANING WELL ANYMORE...
Kind Regards :-)
* If you found this solution helpful, please rate it?
Jun 18, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The "clean machine" edit will
How are you doing the clean cycle ?
You should put a tablet in the coffee grounds front lid.
Push the clean button on the inside front panel.
The machine will ask you to open tap and empty tray along the way.
Make sure it does the full cycle.
Jan 30, 2011 | Jura Capresso Impressa S9 Coffee...
Stuck in cleaning mode?
Open the preground coffee lid, drop a cleaning tablet in it, let it do it's tablet cleaning cycle. After cycle empty water out of tray and clean.
May 16, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Clean machine still on even after cleaning with cleaning tablet
Patti - I had the same problem yesterday with my E8. If you still have an issue, and have cleaned the tamper area like tech support will tell you to do, try this...Turn off the machine and remove the tray. Use your fingers to probe around the metal thing in the middle. You will find several areas where grounds accumulate. I found two areas in particular - one on each side of the center - where I had the motherload of old grounds. Remove all this, then clean out the chute where powder goes. Replace the tray, turn the unit back on and run a cleaning with no tablet. When it asks for the tablet, open the top door, wait a second, close the door and continue. If you got all the gunk out, you should complete the cleaning cycle with no issues. But seriously, you have to use your fingers for the clean out. You can't see, and q-tips don't work..so you have to feel around. Good luck and let me know how it goes.
Jun 20, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
The cleaning cycle is not complete (Jura F9)
This indicates that the Flowmeter is either dirty or defective, it sends incorrect messages back to the electroninc board about the waterflow. It`s located on the left side (seen from behind) as a white sircular box with 2 hoses and an electrical contact on top of the lid.
May 16, 2009 | Jura Capresso Impressa F9 Espresso Machine
TOP DRAWER WHEN LOADED, DOES NOT GET WASHED
top tray not washing properly and tablets not dissolving are linked. On my FDW60 same problem was down to the top tray not being pushed fully home (tendency to use closing the door to push top home). This meant the flap of the tablet 'hatch' was stopped from fully opening by the tray, also poor water pressure to drive the rotating sparge bar on the underside of the top tray.
Be sure to push the top tray all the way home BEFORE closing the door, aaannd SPENT!
Mar 17, 2009 | Dishwashers
Cleaning machine propt will not go away
I have the same machine and had the same issue all day yesterday. Tech support will tell you to clean the tamper (round disk behind the tan/gray "flap"), which you should do. That didn't do it for me, however, so I kept cleaning. I cleaned out the chute where coffee powder goes. Then, after turning off the machine and removing the tray, I used my fingers to go up/under/behind as much as I could get to. I found the motherload of old coffee grounds. It's hard to describe where, but it was all around that metal area in the center. Just keep poking, but use your fingers so you can feel where the coffee is. I tried q-tips, but that didn't work..you have to feel it. After I got all the gunk out, I ran a cleaning again - no tablet - and it no longer said "press rinse" at the end of the cycle. It asked me to dump the tray, and then it went to "ready"! Yahoo - saved a bundle in shipping and repair.
Sep 27, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Malfunction code 8 on Jura Impressa s8
To fix this problem you need to clean the layers and layers of coffee mud off the plates that dispense the spent grounds into the hopper. My suggestion is to do this major muck cleaning before you even put the cleaning tablet in.
Get a flashlight and pull the trays out and have a look at the mechanism that dumps into the hopper. You will see the layers of gunk that need to be scraped off. Easiest thing to get in there is a finger to start, then place it next to your sink and clean it with a water jet from your kitchen faucet, provided your faucet will allow you to do that. Let the runoff go into the sink of course. After you get it cleaned up, then put the machine through the cleaning cycle.
If you can't get the problem solved, the fix is a flat $200 from Capresso.
Call the number above to get set up with a service shipment, done in PA.
Devin in Ohio
Nov 21, 2007 | Jura Capresso Impressa S8 Coffee Maker,...
Dishwasher not cleaning well
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. Good luck!
Aug 17, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
