Schematics for Nady SPA 2400 Stereo Power Amplifier have one one need schematics to properly wire in toroidal transformer.
    Top Expert:
  • Audio Player... Master
  • 76,846 Answers
Sorry those are not available here.
Posted on Apr 26, 2017
Mixer to P.A. system connection
You'll want to use the Stereo Out connections at the top right. You might need adapters to plug into whatever system you're trying to use. Also note that this mixer does not provide power, so the speakers you're using have to be self-powered or be driven by a separate amplifier. You would then plug the Stereo Out connections into the INPUTs of the amplifier.
Jun 28, 2013 | Nady Systems Nady SRM-10X 10-Input Mixer
My Nady xa-900 shut off during performance with no prior indication of problems. Now it will not turn on, no lights or anything. I have two of these amps. One was running Hi Packs, and the other 18
The amp top should be removed to check any fuses and the power transformer, a digital meter will be needed to run these tests, post back for instructions if you have one.
Jul 08, 2012 | Nady Systems XA-900 Amplifier
How to know the serial number of output of nady pmixer 420
Serial #s are usually on the rear or bottom of the device. # of outputs- 2 subs & Mains L&R= 4
you can find the manual below.
http://nady.com/manuals/audio/pmx420.pdf
Good Luck mixing the Next Big Hit!!
Aug 31, 2011 | Nady Systems SPA 2400 Amplifier
I got a used Velodyne SC1250 Amplifier from a friend in the states. Can I switch the power supply from 110 V to 230 V? A pretransformer from 230 to 110 V is to big and not a wishable solution. Are...
If its a transformer based Amplifier you can rewind the primary winding for 230Volt. But it has to be done by a transformer specialist.
All one has to do is unwind the primary on a winding machine and make a note of the number of turnings in the coil. Then wind back twice the number of turns using half the thickness of the wire that was used for 110v.
Eg: if the there were 1000 turns of 20 swg wire in the 110 circuit when you rewind you have to use 40swg wire and wind 2000 turns on the bobin.
Jun 29, 2011 | Velodyne SC1250 Amplifier
Adcom GFA 5500 'mechanical' hum from amplifier
Possibly. Most amps filter out line hum via low-pass filters. If you can locate a schematic, those would be the caps to check.
Apr 24, 2010 | Adcom GFA-5802 2-Channel Amplifier
Need wire schematics -circuit panel box & heat element ARIES SPA
Did you check inside the cover of the control box. Most spa's have a schematic of their components there. Hope it is there.
May 11, 2009 | Home
In need of the wiring diagram with values
contact the company that makes the amplifier. I have bought schematics from car stereo manufacturers before, it shouldn't be a problem.
Mar 28, 2009 | Philips GEMINI XG-3001 Fan...
Problems with Nady Systems TCM 1050
I can fix this. If you look online at homerecording.com you can usually find schematics.
Does the microphone still have a problem, or were you able to return it.
Mar 16, 2009 | Nady Systems TCM 1050 Professional...
Nady 850 amplifier problem
check your speakers cables for short circuit-disconnect all speakers and connect them one by one until you find the bad one and when you find it try the cable first then the speaker -if all above failed you will have a problem in your amp and ask for help from service center
Jul 07, 2008 | Nady Systems SPA 850 Amplifier
 Grubhead
Grubhead
