Question about Xerox Office Equipment & Supplies
My xerox 510dp making noise in scanner unit whenever i tried to copy
    Sergeant:
  • 163 Answers
Http://download.support.xerox.com/pub/docs/xes_510copy/userdocs/any-os/en/510dpopmana_eng.pdf
The manual is attached
Regards
Sir John Dana Hamilton Taylor IQ 397
Posted on Apr 26, 2017
Samsung scx 3200 prints dark but xerox copies are so light that they cant be read
HI PLEASE CLEAN THE CCDUNIT .YOUR PRINTER CCD UNIT IS VERY LOTS OF DEST.AFTER CLEANING CCD THEY PRINT SAMSE SO REPLACE CCD UNIT WITH CABLE
Feb 14, 2014 | Samsung SCX Office Equipment & Supplies
Xerox grinding noise
the bearing on the motor or the rotating path must have damaged..
replace them
Jun 02, 2008 | Xerox WorkCentre Pro 215 Printer & Copier...
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
Hi,i have Xerox Pe220,i am not able to copy as paper comes out blank but i can print from computer,i have replaced new cartridge but same result and put back the old cartridge,PLEASE HELP!!
Iffi,
Are you making copies on the glass or ADF? If you are getting blank copies using both the glass and ADF than your CIS(scanner) unit is bad.
Mar 22, 2011 | Xerox WorkCentre PE220
Xerox C 20 photocopier 'scanner blocked' error message, what can i do?
Try to check green lock under the scanner on the side where your copies went out from copier. maybe you accidentally lock the scanner while trying to get copies.
Hope it helps
Feb 15, 2011 | Xerox CopyCentre C20 Black and White...
My xerox Phaser 6130 is noisy and makes light copies. How do I lubricate it? Will this solve the problem?
The 6130 is not designed to be lubricated, but if you feel the need to lubricate gears, then use white lithium grease. I am not sure the nature of your noise. Loud rattling or repeating ticks could indicate damaged gears, and lubrication won't help that.
Often the Image Unit causes noise and bad print quality. Try replacing that first, PN 675K69244.
Whit
Nov 15, 2010 | Xerox 5665 Copier
Xerox M15: Blank copies
There is a problem with the Laser Unit
need to replace the LASER nit or need to open and clean the unit will solve the issue
Jan 22, 2010 | Xerox WorkCentre M15 All-In-One Laser...
Pages are printing with black lines
If it is making the lines while copying and printing , then the problem is the drum unit.
If it is copy only, then the issue it most likely a dirty scanner or seal glass.
Dec 23, 2009 | Xerox WorkCentre Pro 421Dei Laser Printer
HOW CAN I STOP THE COPIES FROM SHIFTING EVERYTIME?
Wide blank area on Lead Edge, or Misregistration possibly accompanied by noise. The noise may be described as a clicking, buzzing noise while making copies. The noise may stop for short periods while making copies. Cause:
The registration Sol. pawl is not capturing the clutch to keep it from turning. This is caused by the Registration Sol. return spring being out of position, or when installing the Main Drive Assy., the pawl is "trapped" in the actuated position.
Apr 16, 2008 | Xerox WorkCentre XD120F Laser Printer
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
