Question about Garden
HAVE MZT-50 MODEL# 17AA5D7710. HAVE REPLACED IGNTION SWITCH(WHICH WORKED)HAVE REPLACED LEFT NEUTRAL SWITCH (WHICH WORKED) USED THE MOWER, PUT IT UP, EVERYTHING FINE.
1 WEEK LATER GO TO START MOWER AND NOTHING HAPPENS. BATTERY IS GOOD, NEW SOLENOID, RE-CHECKED PREVIOUS WIRING....... NOTHING! ANY THOUGHTS?
3mac
  • 61 Answers
SOURCE: 1993 Ford Thunderbird- New battery & alternator & car won't start
Did you clean the cables when you changed the battery?
I'd trace the wires connecting your alternator and battery and make sure they are "healthy" and securely fastened. Then, I'd check the wires connecting your battery and starter. Again, make sure the wires are securely fastened and appear clean.
The starter and solenoid are one unit for this vehicle.
Hope this helps and good luck!
Posted on Jan 13, 2009
  • 3567 Answers
SOURCE: 1998 Honda Goldwing will not start nothing.
Sort of sounds like a Twilight Zone kind of problem doesn't it. I would have the battery checked for an internal dead short. This is something that happens on odd occasions and can happen even to a new battery. Yea, the little lights will work ( they do not draw much juice ), but the starter motor draws a lot of juice and a shorted battery just ain't got it. Also check the wiring harness connections. One loose connection can cause bunches of trouble.
Posted on Mar 14, 2009
SOURCE: Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
Posted on Aug 15, 2009
SOURCE: Troybilt riding lawnmower - won't start
i have a troy built riding mower, just replaced battery, when i turn key sounds like battery is dead. what could be the problem?
Posted on Mar 28, 2010
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
Is there any way to bypass the switch that engages the blades on my Husqvarna RZ4219 zero turn mower so that it will start?
get a test light, this will make troubleshooting alot easier. check seat switch,stick,neutral,guard and the power in and out of the key. 6 12V Circuit Tester with 5 ft Lead
Sep 04, 2015 | Husqvarna RZ4219 42" 19.5HP Zero Turn Lawn...
Where is neutral switch located on a late model Troy built rider ?
how late a model cus they did'nt put these on till maybe mid to late 80's , infact nowadays they don't do it at all cus they put the switch on clutch/brake pedal as they make you hold it down to start the engine and if it's a pull start there for sure is no neutral switch
May 26, 2014 | Garden
I PUT NEW BATTERY I GET NOTHING
could have a safety switch that is not functioning or a grounding out problem in the igntion system
Apr 06, 2012 | Garden
Keeway hurricane 50 .the electricty went off suddenly
Hello and happy thanksgiving from the USA.
I would suspect that you have a defective igntion switch, the igntion switch is what powers up all of the electrical system when you turn the key to run, the contacts can get burnt or the connector or both. The switch is under/behind the ignition key cylinder which operates the switch or course.
Nov 24, 2011 | 2008 Keeway Hurricane 50
Can you eliminat the fuseable links at the starter solenoid? my 1988 bronco wont start replace all battery cables because the burned up and replace starter and solenoid and still wont start. where should i...
check park-neutral safety switch.
If you can jump start starter right at starter, then look at above or igntion switch. Try starting in neutral too. In case P-N switch is out of adjustment.
Aug 27, 2011 | 1987 Ford Bronco
I have the Craftsman 20.5 Model 944.609800 42 in mower I can get it to run but when i put it in gear or take my foot off the brake it stalls it also stalls when i engage the mower blades can you help i...
I agree it is the seat switch. This switch will let you start the mower as long as it is in neutral, the brake is set and the mower blades are not engaged. I think it is just two wires, maybe you can jump them together and see if it runs.
Gary
Aug 06, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I just got a riding mower (D100) and it has 7 hours on it but the service notification just came on....i checked and it has oil. The belt came off while mowing last weekend but I put it back on and it...
Here are the is the process that the notification will appear:
How Does Your Hour Meter Function? Model Year
Model Number and Product Identification Number Groups. Is the tractor equipped with an hour meter? Does it accumulate hours with the key switch left "ON", but not running? How long does the service reminder (SVC) display before and after service intervals? Does the Hour meter stay lit or display hours when the key is in the" OFF" position? Does the hour meter only count hours when the engine is running? 2008 - 2011 D100 D110 D120 D130 D140 D150 D160 D170 LA105 LA115 LA125 LA135 LA145 LA155 LA165 LA175 Yes No half hour No Yes
The notification should last for 30 mins before and 30 minutes after the service interval before it stops flashing. It is not resetable.
It does make one wonder why it started flashing at 7 hours vs 25 or 50 hours though. Possibly a battery was replaced and the running trime vs the service time intervals are not syncronized.
The service (SVC) arrow indicators will last for 1 hour. It will display ½ hour before the specified service interval and one 1/2 hour after the specified service interval.
The left "SVC" arrow will occur at 25 hour intervals (25, 50, 75, 100 etc.).
A "SVC" arrow pointing to the left will indicate that a general lubrication interval has been reached.
The right "SVC" arrow will occur at 50 hour intervals (50, 100, 150, etc.).
A "SVC" arrow pointing to the right will indicate that service is necessary for the mower and the engine.
Thanks for choosing FixYa,
Kelly
Thanks
Jul 16, 2011 | John Deere Garden
Put mower in reverse, turned it off and mower
There are safety interlocks on zero turn mowers. These prevent starting unless you have: 1. the handles in 'neutral' position 2. the brake on 3. the mower engagement (PTO) switch off 4. yourself in the seat.
Chances are one of these conditions hasn't been met. Since you were reversing when it happened, perhaps you haven't got the handles back to neutral position?
Jul 06, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Is there a deck switch on a YTH180
Hi..my name is Keith...and i havent worked on that lawn mower model..so i cant tell you exactly where the safety switch is..but it sounds like the reverse safety switch has failed and the lawn mower thinks you are in reverse..so i would look around your foward-neutral-reverse shifter for it...i hope this has helped..if not write me back
Jun 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
