Question about Taylor Ice Cream Makers
Bought a 702-33 taylor 3 phase ice cream machine. Is there a way to change it to us single phase?
    Top Expert:
  • Taylor Master
  • 78,267 Answers
Running a three phase motor on single phase power is simple. First you'll need to invest in a variable frequency drive. We recommend using the SMVector Series Variable Frequency Drive for multiple reasons. The SMV is simple to setup and easy to wire. It also comes standard with a NEMA 1 enclosure which gives basic dust and water drip protection. Most importantly, for the purposes of this post, the SMV comes with a number of different single phase input options up to 3 HP
Posted on Apr 26, 2017
I have a Taylor C707-23 that is freezing the product in the barrel and not dispensing. Then the drive motor trips. Had the sensor probe changed same thing.
If this is an ongoing problem that you have had for a while, it sounds as though your viscosity may be set too high. You can adjust the viscosity by removing the 4 screws that hold the face plate on. You will see 3 potentiometers. You want the left most potentiometer. It Should be labeled "Viscosity". You need a tiny screwdriver to turn it. Turn it counter clockwise about 1/16th of a turn. If your Ice Cream is already frozen, You will have to let it cycle a few times before the ice cream reaches consistency. If its liquid, then you will know as soon as the machine finishes the initial freeze down cycle.
If this is a new problem, then it is highly likely that your beater motor is going bad. To check this you would want to test the amperage of the motor when you initially draw product from the machine. A single phase 1.5HP motor in the taylor ice cream machines should not draw more than 7 amp on an initial draw right after freeze down. Its normal to draw around 6 amps then drop for a few second. In order to trigger the reset, the beater motor has to draw more than 6.3 amps for an extended period of time. Your reset may be set higher than 6.3 but that is average.
Jan 16, 2018 | Taylor Ice Cream Makers
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
Jun 10, 2017 | Taylor Ice Cream Makers
Manual and guide for Taylor ice cream machine model 8756-33
For Taylor ice cream machine maintenance, please see our Support page or our Youtube channel. Providing ice cream equipment maintenance to you for free!
Slices Concession
Aug 07, 2013 | Taylor Soft Serve 8756 Three Phase Water...
Looking at a H84-27 how can you tell if its air cooled or if its water cooled?
Air cooled units will have refrigeration condensers, ie: the fins for air to pass over. Water cooled units have water hook ups and black coils inside.
Nov 02, 2012 | Taylor H84 Soft Serve Frozen Yogurt Ice...
I need to know the horsepower rating of the 8756 ice cream machine in order to match a 3 phase inverter to it
Standard is 208/230-60-3. Maximum Fuse: 45 Amps. Minimum Wire Ampacity: 3A. -220/380-50-3.
Maximum Fuse: 30 Amps. Minimum Wire Ampacity:27A.
Jan 11, 2011 | Taylor Ice Cream Makers
Can I change model 754 machine from three phase to single phase by just replaceing the three phase motors with single phase motors?
no you cannot. The cost to replace the dasher motor and compressor would be extreme. In addition, you would need to convert the controls from 3 phase controls over to single phase controls.
Those machines are designed for 3 phase power. If you could get the same components in a single phase version, you would spend more money economically than its worth.
Take the money you would spend converting and purchase a single phase countertop unit. They are made.
Feb 11, 2010 | Taylor 632-27 Ice Cream Maker
Taylor ice cream maker single serve
You can't. Taylor won't send you one unless you are a foactory trained technician. Sorry
Oct 19, 2008 | Taylor 632-33 Ice Cream Maker
what model machine and what do you need to know.
Oct 17, 2007 | Ice Cream Makers
Ice Cream Makers Logo
236 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
