Question about Refrigerators
Lfus2613lfo frigadare low voltage 60vac at freezer fan. Causes?
    Top Expert:
  • Refrigerators Master
  • 77,939 Answers
Are you making the voltage measurement with the motor connected?
Posted on Apr 26, 2017
Frigadare refrigertor side by side its cooling fine but the freezer wont freeze
Check the heater coil in rear of freezer. Mine was burned out. Letting ice build up on the cooling fins. Replaced with new type double heater coil and fixed proble. You'll have to remove the cover off rear wall of freezer section to access it.
Jul 04, 2014 | GE GSS20IEP Side by Side Refrigerator
Frigidaire lfus2613lfo beeping
Check the condenser is clean and the fan running. Check for compressor hummimg
Apr 22, 2014 | Refrigerators
Thermo set "heat" and "Auto
Check the fan relay. These relays are used to cut the fan on and off when the thermostat is set in the air conditioning or heating mode or when you move the thermostat to the "Fan On" position. The low voltage usually the green thermostat wire is wired to terminal #1. The low voltage common wire to terminal #3. One line voltage wire is attached to terminal #4. The high speed blower wire usually black is attached to terminal #2. When the thermostat calls for air conditioning or "Fan On" the 24 volt coil is energized, the terminals 4 and 2 close. This causes the fan to come on in high speed. When your home cools down and the thermostat cuts the air conditioner off, the low voltage coil terminals 1 & 3 are denergized, and the fan goes off. Sometimes these little relays stick which causes the fan to run all the time or will not make good contact, which causes the fan to not run in the "Fan On" or air conditioning mode.
Nov 16, 2010 | Weather King 10AJA6001AH Air Conditioner
GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Dec 10, 2009 | Hotpoint HSS25GFP Side by Side...
Frigadare freezer gets very cold, lower refrigerator gets no cold at all
This is because your refrigerator is not cooling, your thermostat does not detect the proper cooling and does not cycle off compressor - your compressor is running continually - since your refrigerator's cooling rlies on your freezer. We can rule out fan problems as your evap fan in the freezer is working - If your refrigerator is barely keeping cool but not enough you probably have a gasket leak - if it not cool at all you likely have a damper problem - the damper is a flap that gets opened / closed as needed - yours is probably stuck - when you get it serviced they will need to check damper & control boards. I assume also you have checked to see if there is any vent obstruction in your fridge.
Sep 05, 2009 | Electrolux Refrigerators
My refrigerator constantly runs and is not cold enough. Could it be the control temp?
  • Freezer fan and its circuit problem.
  • Defective fan motor.
  • Defective defrost timer,defrost heater or defrost terminal thermostat.
  • Temperature control failure.
  • Compressor motor defective. Inefficient compressor (low wattage readings).
  • Condenser fan.AC circuit to fan open (high wattage reading). Defective fan (high wattage reading).
Aug 19, 2009 | GE Refrigerators
During low voltage period window AC compressor shudders and kicks off, but fan runs, when voltage returns normal compressor runs.
low voltage issues causes higher amp draw and equipment to run a lot harder. whats causing the low voltage problem to the equipment? high amp draw of the compressor could be causing it to overheat and trip until the compressor physically cools down.
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Dead JBL EON 15P-1
did you measure 60vac across total secondary or 60vac from center tap?
Feb 27, 2009 | JBL Eon15P-1 Main / Stereo Speaker
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
