Question about Toys
Where is 856 - Toys
    Top Expert:
  • 77,529 Answers
Area code 856 is an area code located in the U.S. state of New Jersey created in 1999 by a split of area code 609.[1] It covers southwestern New Jersey, especially the Camden/Cherry Hill and Vineland areas, as well as a very small part of Willingboro Township, along with the western part of Burlington County, while 609 covers the rest of Willingboro and the areas to the north and east.[2] 856 is virtually coextensive with the New Jersey side of the Philadelphia metropolitan area.
Posted on Apr 26, 2017
Where is area code 856
Apr 26, 2017 | Toys
Farmall 856 hitch does not raise in zero weather
ck to see what hydraulic oil your using , I bet it's an all weather rated oil, if temp is below zero then that's out of "all weather" range , you will need to look into using a cold weather rated oil (ck with you local dealer to ask ), my tractor has an oil bypass lever you can engage on the valve block this allows oil to circulate around in loop to heat up (+20 degrees) to work in cold temps , I don't think a 856 has one of them
Jan 21, 2016 | Farmall IH Tractor 706, 756, 806, 856,...
Where is the air filter for model #7665 856
if there is a filter you should see it. if not... run the unit on hi and follow the sound to find the air inlet. as said... if there is one you should find it easily.
Jan 06, 2015 | Heating & Cooling
I have an old (20-25 years) Daisy powerline 856. Uses BBs and pellets. Never been fired. I would like to give it to my grandson but I have no manual. How can I find one? I can find the 880 manual but not...
Daisy Powerline 856 Manual
http://www.ebay.com/itm/Daisy-856-860-Rebuild-Reseal-Kit-Seal-Gun-BB-Air-Rifle-Set-O-Rings-Parts-Seals-/152432029624
https://thefiringline.com/forums/showthread.php?t=86965
COMMENT Federal Regulation of BB Guns Aiming to Protect Our Children
You might enquire about a product recall for the 856 but the original page referring to the recall has been removed. info@cpsc.gov
Or you could try contacting Daisy and see if they retain any information about any modification (but they are unlikely to have any parts for it, now.) The problem was that the earlier design of the 856 and 880 allowed a pellet to be lodged in the mechanism, unknown to the shooter. This could result in inaccuracy during firing. The 856 was modified to single shot rather than magazine by 2001 at which time Daisy was not found culpable in several deaths (resulting from direct firing at a party). I retrieved the findings using the Wayback Machine at the Internet Archive. The US Government site has removed the findings for some reason.
Jun 03, 2017 | Toys
How do i remove the PTO from an IH 856. The lower PTO shaft broke and the unit will not slide out
make sure all the bolts are out should be 1 short bolt and 8 long bolts to remove pto after that it is stuck to gasket. short bolt is in lower left corner of housing
Dec 26, 2012 | Farmall IH Tractor 706, 756, 806, 856,...
Broken hinge mount on shaver head
On model R-856, the hinge comes with the head holder. You will find this part available at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-hairpocket-and-hinge-assembly-for-model-r-856.html
Feb 18, 2010 | Remington MicroFlex R856 Electric Shaver
Toys Logo
43 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
