Battery won't stay chaRGED NO AMPS SHOWING ON AMMETER.CAN BE STARTED BY JUMP AND WILL RUN BUT STOP AND WILL NOT START AGAIN WHATS MY PROBLEM?
it could be a fuw things doing this,,,
check that the engine is charging the battery up when its running,,use a volt meeter across the battery it should show 13.5 volts if its charging up ok,,,,
then check that the voltage regulator is not draining the battery when the engine is not running,,,
fully recharge the battery first then check that it holds this charge,, take off the battery lead and leave the mower for a week or so if the battery has gone flat then you need a new battery!! winter time kills off batterys if there not kept on trickel charge,,,
there's a tip,,,,buy a solar charger,,,and hook it to the battery when your not using the mower,,it will keep the battery toped up for free???
