Can't get new toner cartridge all the way back into the Xerox 4CP copier/printer. Does the power need to be on to do it?
    Scholar:
  • 87 Answers
No the power is not needed. You probably forgot to pull the packaging tab out of the toner before you installed it. Refer to your toners instructions. This tab keeps the toner in the package in shipment. Do not force it in. You will destroy your printer if you do.
Posted on Jul 25, 2009
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox 3250 printer smudges with new toner cartridge
Go to the settinge. Go to maintenance a perform the cleaning steps.If that doesn't correct exchange cartridges . Remember recharged cartridges have problems. Possible you need to shake the cartridge.
Feb 25, 2013 | Xerox Phaser 3250DN printer BW laser...
Refilling toner in xerox phaser 6280
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your model printer.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 27, 2012 | Xerox Phaser 6280 Clr Laser Printer 26Ppm...
When the red light blinks on the printer what does it indicate-model-xerox phaser printer 6110
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2
from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
Apr 06, 2011 | Xerox Phaser 6110 Laser Printer
Xerox DocuColor 4CP printer will not print colour. It will print black fine though. Have defaulted printer and printed colour page, still no colour, just black.
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=DC4CP&Xlang=en_US&Xcntry=USA
According to this site, Windows 7 drivers are available for the Xerox Docucolor 4CP printer.
What operating system are you using?
Also, is it possible that your color toner has been depleted?
Jul 18, 2010 | Xerox Office Equipment & Supplies
Changing black toner cartridge
To change your toner first turn off the printer and unplug it from the power outlet. Then, lift the toner door. Carefully grap the toner cartridge from both ends and lift it up. Do not shake the toner as you may get dirty. Then take the new toner cartridge, remove any plastic covers and insert it in the printer. Close the toner door and start your pritner.
Feb 08, 2010 | Xerox Phaser 6120/YN Laser Printer
J1 Error, Changed a brand new factory-sealed toner, still getting J1 Error
Make sure you have the right code: J1 or J2.
one is for the drum and the other is for the ink.
Make sure the toner unit is for this model and not for a different model.
If the old modual is still available, check the connectors at the back and see if they are the same.
If anything else Call Xerox for repair. If the cartridge was bought through Xerox have your reciete available for warrenty.
If repairs still need to be made, A Xerox service call may be needed in order to fully repair the copier and warrenty the cartridge.
Nov 06, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
27 people viewed this question
jasbo
jasbo
