Question about HP Garden
I need to know the valve clearance for a kohler 24 hp engine
    Top Expert:
  • HP Master
  • 78,010 Answers
Intake Valve Lash8 0.127 mm (0.005 in.)
Exhaust Valve Lash8 0.178 mm (0.007 in.)
Posted on Apr 26, 2017
Can the overhead valves on a 16hp sears craftsman with a kohler engine be the reason why it won't start and if so, can I adjust them
Valve clearances will also effect the decompression valve in the engine, if they are too wide the valve lifter will not work and the battary will not have enough energy to crack the engine.
Jun 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Valve clearances
mine has hydrodrolic lifters no adjustmetn
Aug 21, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Replacing 24 hp B&S with a 20 hp kohler, need to
Yes I agree. I would figure that out first before changing the engine.
Sep 07, 2011 | Briggs & Stratton Garden
Craftsman 24 HP 42" mower...has always been hard
If it has the Briggs or Kohler engine, it has a built in compression release. If the release isn't working properly, it will be hard to start. It mimics a weak battery. One remedy to enable the compression release to work properly is to adjust the valves. They need to be adjusted periodically. Briggs has all the valve clearances for all their engines in an easy-to-use chart. I will give you valve service instructions and then the engine chart with all the valve clearances.
May 14, 2011 | Craftsman Garden
How much compression should a kohler 25 hp engine have
hi there
there are no published compression limits for kohler
the prefered method is to have the cylinders leak tested , because of the decompressor action built in while trying to compression test
but off the top of my head most machines would run best with a minimum of 100 psi or better
given that these have a compression ratio of 9:1
you could work it out
9:1 X 14.7 PSI ( 1 amtmosphere ) @ sea level = 131.00 psi
compression ratio = swept cylinder volume + clearance volume (@ tdc) divided by clearance volume
here is web site for obtaing service manual
login as guest
select command pro twin -ch/cv 17-26
go to service manuals , select sm 24-690-07 file is 8.82 Mb and double click it and save a copy to your hard drive
cheers hope it helps
May 07, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
Garden Logo
27 people viewed this question
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
