Question about Building Materials
My Genie Blue Max opener has become very noisy. I lubed the screw, but it didn't help. Is there anywhere else to lubricate?
    Top Expert:
  • 76,846 Answers
More then likely the motor is the problem, it is in need of replacement.
Posted on Apr 26, 2017
Replacement motor bearings for a genie shop vac/blower model# pb 15
Unfortunately those machines do not have serviceable bearings. The entire motor needs replaced. However, I have saved noisy bearings by putting oil on them, specifically 3 in 1 Blue Label motor oil. A few drops spread on the top and bottom of the bearings and giving the motor a few backward and forwards turns by hand will help those bearings immensely.
Feb 20, 2016 | Genie Company Vacuums
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
Unable to program universal opener with genie pro max garage
Actually, this remote can be used with Genie Garages. See the article here on eHow - I used this to program a KLIK1U to work with my Genie Promax 2 garage. Hope that helps!
Oct 11, 2012 | Chamberlain Clicker Universal Remote...
Noise while in use
First, check the ramp area. A ramp with worn groove marks can become quite noisy. It could also be coming from a bearing in one of your wheels. If the noise seems to be coming from the rear of the machine, attempt to lubricate the moving parts and the different connection points. Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
May 29, 2012 | Precor EFX 546i Elliptical Version 4
Runs but noisy
Look in the drum. If you see 3 screws in about a three inch circle in the center of the back, then it rotates on a ball and socket. These get dry and or loose. You can try greasing it with a very high temp grease (try one for lubing disc brake calipers on cars) or it may need to be replaced. If you don't see those screws, it probably runs on rollers which either need spray lube (such as WD40) or replacing.
Nov 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Opener only raises the door one foot.
IF THE DOOR IS BALANCED TRY ADJUSTING THE SENSITIVITY.
THE DRIVE SHOULD BE LUBED WITH WHITE LITHIUM OR GENIE LUBE 2 TIMES PER YEAR TO KEEP THE UNIT QUIETER AND PREVENT EXCESS WEAR.
IF YOU USE THE WRONG LUBE - GREASE ETC. THE UNIT WILL GET GUMMED UP AND WILL HAVE PROBLEMS IN COLD WEATHER.
ONCE YOU ADJUST THE SENSITIVITY YOU SHOULD BE OK.
Aug 24, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Building Materials Logo
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
