Question about Dell Dimension 5100 (D51L1) PC Desktop
I have the same problem
There is no door to gently pull open. It is just a slot.
    Sergeant:
  • 157 Answers
Then take the Slot out.
Posted on Jul 25, 2009
How do i remove the uv bulb
Place your finger in the door recess on the right-hand side of the sanitizer and pull open the door.
Remove the drip tray.
Remove the protective screen by gently lifting it up and pulling it forward.
To remove the UV light bulb, pull it out of the lamp holder.
Install the UV light bulb by snapping it into the lamp holder.
Align the pegs on the protective screen with the slots in the reflective surface of the sanitizer on either side of the UV light bulb.
Insert and gently push down the screen to secure it in the sanitizer.
Reattach the drip tray.
Dec 13, 2014 | Air Purifiers
Fitting new door seal
Door seals are in a formed groove/slot.Grab the one end and pull the seal out.Putting the new one in is harder.Use a light lubricant,like vasoline,that will just dissipate after a while,and gently pull the new seal into the groove/slot.I've had to do this myself.
May 01, 2014 | 2002 Mitsubishi Diamante
Push upward latch for door is stuck, will not open after wash
Gently place a wide bladed device like a screw driver, paint scraper, or spatula, in-between the upper slot of the door and the lower part of the counter. Lift "UP" with little force so you do not chip the door surface, and try to release the door by having someone pull down and toward you. When it opens, have some one help align the locking tab, slightly bending it upward.
Mar 16, 2014 | Dishwashers
How do I replace ink jet in officejet 4500
Step one: Remove the old cartridges
1. Press the power button to turn on the product
2. Open the front access door. The carriage moves to the far right side of the product
3. Wait until the carriage is idle and silent, and then lightly press down on the cartridge to release it.
To replace the tri-color cartridge, remove the cartridge from the slot on the left.
To replace the black cartridge, remove the cartridge from the slot on the right.
Pull the cartridge toward you out of its slot.
Step two: Install the new cartridges
1. Remove the new cartridge from its packaging. Be careful to touch only the black plastic.
2. Gently remove the plastic tape by pulling the pink pull tab
3. Hold the cartridge with the HP logo on top, and insert the new cartridge into the empty cartridge slot. Make sure you push the cartridge in firmly until it snaps into place.
If you are installing the tri-color cartridge, slide it into the left slot.
If you are installing a black cartridge, slide it into the right slot.
4. Close the front access door.
May 27, 2013 | HEWLETT-PACKARD Officejet 4500 All-in-One...
How do I change cabin air filter in 2006 m35? video or pics?
First, you need to remove the glove box: Open the glove box. There are three hinge points at the bottom of the box (left, center and right). There are "tabs" on the box that slide into these "holders". Gently pull up and out on the left side of the glove box. The tab should pop out. Repeat for the center point. This should allow the left side stop pin to clear the dash slot. Repeat for the right side. You should now be able to turn the box, pull it from the dash and let it hang from the retaining cord on the right side. Note the hinge slots and tabs for reference for re-installation later. Second, remove the black access door behind the glove box: This is an "L" shaped cover with three hinge points at the bottom and three tabs at the top. Gently push back on the tabs at the top to un-lock, rotate down on the hinge points and pull out. Behind this you will see a white plastic door which covers and holds the filter in place. Third, remove white access door as follows or you will break the retaining tabs off! On the right side is a locking tab, gently press in and pull the right side of the tab toward you to unlock the tab BUT STOP AS SOON AS THE TAB UNLOCKS THE DOOR AND OPENS ABOUT ½ " or the tabs on the left side will break off, they are not hinged! Next, slide the door to the right to clear the tabs on the left side and remove. Note the position and orientation of the filter inside. Remove the old filter. Fourth, install the new filter: Make sure the orientation and air flow direction are as marked and match previous filter. Mine was pointing "up", with the rigid side plate facing out. The new filter will be sitting on top of the fan, when the white door is re-installed, it has "fingers" that lift the filter into the proper location, but you may find it easier to lift the filter up with one hand and slide the door back into position with the other hand. That said, lift the filter, slide the tabs on the left side of the door back into there slots. Push the door back into original position and latch the right side locking tab. Make sure the door is sealed and back to original position and latch tab on the right is locked. Now, reverse the previous steps to complete the task. Re-install the black access door cover. Lift up the glove box and turn to install right side stop pin into dash slot position, rotate left side into position and center box in dash opening. You will have to move the box up/down, in/out a bit to "feel" the hinge tabs properly engage the hinge slots. Once the tabs are in the slots you can push down on each side and it will pop back in place. (If you have difficulty, you may want to remove the under dash cover below the glove box. There are three tabs in the front that slide into three slots and one tab and slot in the rear. This can be removed by pulling down on the front of the panel at each side and the middle, then slide it forward out of the rear slot. Disconnect the light if required by pushing the latch on the plug and pulling it off. Feel around the hinge locations to guide the parts together).
Read more: http://wiki.answers.com/Q/How_do_you_change_the_cabin_air_filter_on_a_2006_Infiniti_M35#ixzz1NKCLa6qC
May 25, 2011 | 2006 Infiniti M35
Need to find out how to put ink cartrdiges back into hp 5610 all in one printer.
First, turn the printer on. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right Pull the print cartridge toward you out of its slot.
Now we're ready to install the new cartridge. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket. Close the print-carriage access door.
Mar 21, 2011 | HP Officejet 5610 All-In-One InkJet...
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How to load the ink cartridge
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
The DVD will not stop spinning. The door will not open either. When I took the cover of the players and plugged it in, the DVD just keeps spinning even when I hit STOP, OPEN, and turn the player OFF. ...
I've had this problem twice now.
The first time, I unplugged the unit for about a minute, plugged it back in and pressed the Open button. The disc was ejected and ran fine for about a week.
Then it happened again, but the unplugging didn't fix it this time.
Try this;
Unplug the unit and let it sit for a few mins to let the disc stop spinning. Then gently pull down on the DVD door. Look at the lower left side of the DVD tray and you should see a large slot. Shine a light into the slot and you will see a dime size white gear. I used a small flat head screwdriver to spin the gear to the right. After 2 small turns, the DVD tray opened enough so that I could pull it gently open. I took the DVD out, gently pushed the DVD tray back in and set the DVD player on my workbench to tinker with on a rainy day. Not sure what the root cause is, but I'll worry about that later!
Aug 14, 2009 | Samsung DVD-R135
Honda pilot door locks
It is because the door actuator is bad in those doors.
Replacements can be found at the dealership for around $60 or on Ebay for as little as $10. Number 5/24 in the diagram below. Actuator part # Left Side 72155-S5P-A11 & the Right side 72115-S6A-J01.
Expect to set aside at least 1-2 hours on the first replacement, lesser time on the ones afterwards. Be careful not to push parts in directions that they shouldn't be pushed in. Don't break any plastic parts/metal rods or connections - take your time.
1. Remove the plastic tab under the inner door latch.
2. Open the 2 small black colored screws.
3. Carefully swing the door latch attachment out by moving it down and out. Remove the rod and the electrical connection - there's a slot to press and pull-out.
4. Use a flat screw driver to carefully pry the window opening plastic area (its one piece and includes the cup holder). Remove the electrical connection - there's a slot to press and pull-out. Open the screw beneath the arm rest.
5. Use a flat tool (I used a metal putty 5-in-1 tool) to slide between the door metal and plastic areas - pull the plastic buttons/connections off, you'll hear them pop. Slide the door out.
6. Gently open the white plastic sheet about a quarter of the way from the top right down so you can reach in the actuator area (near the door latch - at the end of door with 3 screws). Remove the window guardrail, if its in the way - use a 3/8 bolt.
7. Use correct amount of force, without stripping them, open the 3 screws at the door latch.(Best to use a Handheld Impact Driver)
8. Take a good look at the connections inside. Disconnect the electrical connections (two of them) on the lock actuator.
9. Gently but forcefully (without breaking any plastic or other parts), push the metal connectors back and carefully remove the door lock actuator assembly from the door.
10. Replace with new actuator and assemble in reverse.
Nov 24, 2008 | 2004 Honda Pilot
Dell Dimension 5100 (D51L1) PC Desktop Logo
66 people viewed this question
Alun Cox
