Question about Sharp Microwave Ovens
What are the reset steps on display panel to unlock Sharp Pro Insight Microwave KB6525PS?
    Top Expert:
  • Sharp Master
  • 76,846 Answers
Unplug the machine for 5 min's is the only reset. Most likely the control panel is defective.
Posted on Apr 26, 2017
5 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Display panel
If you or a firend can desolder the one CPU coard from the power board then solder the new one in, you can order part # DPWBFC167WRKZ from Encompass (formerly Tritronics) for $107.07 plus shipping.
Otherwise, we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 03, 2009
  • 4 Answers
SOURCE: Sharp microwave oven LCD display malfunctions
Might or might not work. IT worked for me.
This is a common problem. i havent completly solved it yet but this helps.
Be very careful doing this, There is Voltages with AMPERAGES high enough to boil your blood inside a microwave.
I had mine apart cleaning it. Only one number worked on my display. I wiggled and messed around with the wires in the back of the display. And almost every number in the display works again. Hope this helps.
Posted on Mar 07, 2009
  • 338 Answers
SOURCE: Dim Display Panel on Sharp Convection/Microwave R-1851
its a common problem with the sharp microwaves. the control pcb needs to be replaced. it should come with the clock attached to it.
Posted on Mar 13, 2009
SOURCE: Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Posted on Oct 28, 2011
I have a Sharp Insight Pro KB6025MS. the power is not on but it is plugged in...whatis wrong? -
have you checked your breaker to make sure it is on? If it is then check at the plug and see if you are getting power to the stove.
Jun 14, 2014 | Sharp KB6025MS Stainless Steel 1000 Watts...
Sharp KB-6524PS no power
There probably is a fuse inside but replacement depends upon your degree of comfort with disassembly while maintaining awareness of the dangerous voltages lurking inside.
Jan 14, 2014 | Sharp Insight Pro Series KB-6524PS 24""...
Drawer tries to close and then opens
I would suspect that a foreign object may have gotten in the pathway of the drawer, the drawer actuator is out of adjustment, or one of the door sensor switch is damaged, defective, or off its mount.
The service manual is at our site here.
You can order Sharp parts from Encompass here.
Nov 02, 2012 | Sharp KB6024MW Insight Pro 24" Built-In...
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Where can I buy a Sharp drawer microwave in the UK?
    Hi
    You can check out these links to buy Sharp Microwave in UK:
    Link 1
    Link 2
    Hope this helps...please post back for further assistance.
    Daniel
    Mar 18, 2011 | Sharp Insight® KB-6002 1000 Watts...
    Comes on but it wont heat up
    Mine just started doing this... pushing on the left side of the drawer results in a "click", and then it will actually work. I suspect there is a switch/contact in there that is worn/malfunctioning, but am still researching it.
    Dec 31, 2010 | Sharp Insight Pro Black 30" Microwave...
    Feb 05, 2010 | Microwave Ovens
    Microwave Ovens Logo
    29 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
