Question about The Health & Beauty
What is the light that has started flashing at the bottom of the joystick control panel? The chair will not go. If I turn it off and back on, it will go so long as no one is sitting on it.
dromtonpa
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. smithrmrm70@hotmail.com
Posted on Sep 07, 2009
SOURCE: Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Posted on May 18, 2010
Testimonial: "That was the problem, Thanks !!!"
  • 7 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair, it is the secondd row of ligths on the controller, the ones that indicate speed. They are flasing steadily
Check that you don't have the charger cord still connected or the motor disengaged.
Posted on Jun 01, 2010
Lights flashing when turned on, replaced batteries,fuse, in drive position
the amount of flashing lights will give you a Flash code. If the the lights are going up and down, you may have a locked joystick. one method is to turn on and (within 10 sec.) push the horn button twice. Push the power button then push the joystick forward until there is a beep sound then back until you hear a beep sound to unlock.
Mar 30, 2016 | Pride Go Chair Power Chair
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
Mar 28, 2016 | Pride Mobility Used Power Chairs Jazzy...
Light flashes 7 times
7 Flashes indicates a joystick trip. Turn off your chair, ensure the joystick is in center position without anything touching it and turn on chair. This should clear the 7 flash code.
This problem is quite common amongst power chair users. It typically occurs when something is pressing against the joystick as you are turning the chair on.
Feb 14, 2014 | Select Jazzy Used Electric Wheelchair
How do i reset a jet 7 mobile wheelchair
did you put it in lockout accidentally? try this! turn off chair, press and hold the on button till a beep is heard, push and hold the joystick forward till a beep is heard, then pull back and hold joystick till beep is heard, turn off, and turn on. it should work now?
Sep 04, 2012 | Jet 7 Portable Power Chair
I JUST PURCHASED A JAZZY WHEEL CHAIR AND IT IS I THINK 2003 MODEL WHEN TURNED ON THERE ARE 3 RED LIGHTS AND 4 YELLOW LIGHTS FLASHING AND NOTHING HAPPENS
the 7 lights indicate a joystick problem which means the joystick/controller will have to be replaced since there is no self repair fix Unless you can locate a good used joystick/controller for cheap (around $600.00 rebuilt) I would return the chair and get my money back Hope this helps
Jun 20, 2011 | Pride Jazzy 1103 Ultra Standard Power...
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
My pronto m51 sure step service light is flashing seven time and it will only turn to the right
sarah check the joystick cable try unplugging it from the rear of the joystick and plugging it back in then unplug it at the back of the chair and plug it back then turn the chair on to see if you are still getting 7 flashes. If you are then you have one of 2 problems the joystick cable somehow is bad or the joystick itself has got a problem try the cables first to see if it fixes the problem If Medicare paid for the chair then they will pay for most of the repair Contact Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Apr 02, 2011 | Invacare Health & Beauty
Speed lights flash alltogether at the same time chair will not run
The chair is in sleep mode or lockout mode. To unlock-- turn on the chair, immediately push the joystick straight forward until you hear a beep then push it straight back until you hear another beep then release to center. This should unlock the joystick. Turn the chair off then back on and you should get normal operation Hope this helps
Jan 27, 2011 | Pride Jazzy 1113 Power Chair
Jet 3 flashes "code 7".
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
Nov 30, 2010 | Jet 3 Ultra Power Chair
Pride mobility Jet 3 Ultra Power Chair 7 flashing lights. joystick error. how do i fix ? Three red LEDs Four yellow LEDs
Sep 06, 2009 | Jet 3 Ultra Power Chair
Health & Beauty Logo
23 people viewed this question
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
