Question about Garden
Removing flat idler pulley from drive system cannot get ref. # 9 Hex Screw Part # 710-3011 to back out to replace the idler pulley.CUB CADET LGT 1054
    Top Expert:
  • Garden Master
  • 77,947 Answers
Try heating the screw.
Posted on Apr 26, 2017
I have a Cub Cadet LGT 1054 It just quit running and doesn't do anything when key is turned.
If the battery is good, The pressure switch in the seat might be stuck, or unplugged, The switch shut down power to everything when you are not on the seat
Nov 27, 2016 | Cub Cadet Garden
I have a 2006 Cub cadet LT 1045. My model only has one idle pulley. I am having a hard time keeping belts on. Does anyone know a fix for this
have you got the belt on the right side of the idler pulley
the back of the belt should be running on the pulley
Sep 25, 2015 | Cub Cadet Garden
When I try to lower engine rpm by retarding the throttle control to idle the engine speed does not change?
Your throttle cable is screwed up , you can probably fix it without buying anything. It probably just came unattached
Jul 02, 2015 | Kohler Cub Cadet LGT 1054 54" 26HP Lawn...
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
How to replace drive belt on cub cadet 1050
Fairly easy to replace once the deck and the electric PTO are removed just make mental notes or rough of the belt path before removing the old belt. One thought if I remember correctly this uses 7/16" belt and a 1/2" width will not work due to the tight clearance at the engine pulley so stick with OEM belt.
Oct 14, 2014 | Cub Cadet Garden
Cub cadet belt keeps coming off the deck
Link to see video of the Fix for cubcadet deck belt coming off can be viewed here:
Apr 21, 2012 | Cub Cadet Garden
Cub model 1170 drive wont disengage
there should be a pulley somewhere in the belt assembly that lifts up ti allow slack in the belt. your problem sounds to me like you have messed something on the clutch up and the pulley isn't lifting up to let there be some slack in the belt to disengage the drive.
Jun 14, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
