Question about The Optics
Distance through the center of an object - The Optics
  • james laughton
    james laughton Apr 28, 2017
    Hi Dustin Tholl, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How do i the camera to take smaller pictures and if it is by using the zoom do I zoom in or out.. Thanks
Hi sportingnut4 ,
Thanks for the question ,
  1. If you mean by smaller pictures i.e. small in area you have to capture the images keeping the distance in perspective.
  2. If the distance between the image and camera is more , you would find the object being captures is small and if the distance is less , you would find that the object that has been captured is bigger.
  3. If you want to capture an object which is far away you can use the Zoom In function which would zoom your camera's lens in the object.
  4. If you have already Zoomed in , then to decrease the zoom i.e. to go away from the object as if you are increasing the distance between the object and the camera , you should Zoom out.
  5. Remember , Zoom out usually only works when you have already used the Zoom in function of the camera.
Hope this helps.
May 11, 2011 | Sanyo VPCE890 Digital Camera
My 2007 Yukon has a problem with the park assist sensors. When I go in reverse sometimes, the warning beep repeats quickly and the lights flash like crazy but nothing is behind the vehicle. Sometimes the...
Check the system for DTC'S - diagnostic trouble codes should be the first step in the diagnostic process . Then reading factory service repair manual how the system works , viewing wiring diagrams .
Object Detection Description and Operation
Ultrasonic Rear Park Assist Operation
The ultrasonic rear park assist system senses how close the vehicle is to an object. The distance is determined by the 4 object sensors located in the rear bumper. The object detection system will notify the driver when backing up at speeds less than 8 km/h (5 mph). The object detection system will use the rear parking assist (RPA) display and the radio speakers for notification.
When the ignition is ON and the vehicle is placed into reverse, the object detection system performs a bulb check. During the bulb check, the 3 indicators on the RPA will illuminate for approximately 2 seconds to indicate that the system is working. The object detection system performs a bulb check and operates when the following conditions are present:
• The ignition is ON.
• The vehicle is placed in REVERSE (R) for rear parking aid.
• The vehicle speed is less than 8 km/h (5 mph). At speeds greater than 8 km/h (5 mph), the object detection system is disabled. The red indicator flashes to warn the driver that the object detection system is disabled.
The object detection system senses how close the vehicle is to an object. The distance is determined by the 4 object sensors located on the rear bumper. When the system detects an object, one of the following will occur:
• If the object is less than 0.3 m (11 in) away from the vehicle, the amber outside, amber middle, and the red outside indicators flash and the chime sounds continuously for 3 seconds.
• If the object is less than 0.3-0.5 m (11-20 in) away from the vehicle, the amber outside, amber middle, and the red outside indicators are ON.
• If the object is 0.5-1.0 m (20-40 in) away from the vehicle, the amber outside, and the amber middle indicators are ON.
• If the object is 1-2.3 m (40-91 in) away from the vehicle, the amber outside indicator is ON with a single chime when the object is first detected.
Object detection system can detect objects 7.6 cm (3 in) wide and at least 25.4 cm (10 in) tall. It cannot detect objects above the level of the roof.
If the object detection system detects a malfunction, a diagnostic trouble code (DTC) will be stored and the object detection system will send a serial data communication message to the instrument panel (I/P) to SERVICE PARK ASSIST message on the driver information center (DIC). Then the chime will sound and the red indicator on the information telltale center will be lit continuously. The red LED in the rear display will be lit, notifying the driver that a malfunction exists. Message will clear once the driver acknowledges it.
Each object sensor is a three wire sensor that is both a transmitter and a receiver that comprises a signal circuit, a low reference circuit, and an 8-volt supply voltage circuit. The rear object control module supplies 8 volts to the object sensors via the object sensor supply voltage circuit and provides ground via the low reference circuit. The rear object control module triggers the sensors in a sequential loop and after each sensor transmits, the rear object control module uses the echo or signal return to calculate the distance and position of an object from the rear bumper. The rear object control module directly controls the RPA display.
Do you know what DTC'S are ?
DTC B0958 01: Parking Aid Rear Sensor 1 Left Corner Circuit Short to Battery
DTC B0958 06: Parking Aid Rear Sensor 1 Left Corner Circuit Short to Ground or Open
DTC B0958 08: Parking Aid Rear Sensor 1 Left Corner Circuit Signal Invalid
DTC B0958 21: Parking Aid Rear Sensor 1 Left Corner Circuit Incorrect Period
DTC B0959 01: Parking Aid Rear Sensor 1 Left Middle Circuit Short to Battery
DTC B0959 06: Parking Aid Rear Sensor 1 Left Middle Circuit Short to Ground or Open
DTC B0959 08: Parking Aid Rear Sensor 1 Left Middle Circuit Signal Invalid
DTC B0959 21: Parking Aid Rear Sensor 1 Left Middle Circuit Incorrect Period
DTC B0967 02: Parking Aid Switch Circuit Short to Ground
DTC B0968 00: Parking Aid Indicator Circuit
Your best bet , take it to a qualified repair shop.
Feb 04, 2018 | GMC Yukon Cars & Trucks
250J of work is done when a force of 50N is applied on an object. calculate the distance through which the object moves
Work = Force X distance
250J = 50N X distance
Consider that 250J = 250 N.m(Newton meter or Newton multiplied by meter)
250Nm = 50N X distance
Divide both sides of the equal sign by 50Nm and the answer is 5m
Nov 08, 2010 | 1990 Daihatsu Charade
When i look in the finderscope the objects r upside down but when i look in the big one theres nothing,even when i try and zoom in and out thers nothing moving
Some finders show things upside down. There is no up or down in outer space.
During the daytime focus on an object like the top of a telephone pole a good distance away.
Without moving the telescope adjust the finder scope so that the "crosshairs" in the finder are centered on the same object as the main tube. Most astronomical telescopes show upside down and reversed images.
Nov 04, 2009 | Meade (r) TeleStar Manual 60mm Refractor...
My Pinseeker 1500 picks up objects at close distances (50 yds +/- but not at longer distances. Whats wrong and is it an easy fix?
This unit needs an alignment. If it has oily looking spots in the display it also needs the LCD replaced. If it is less than 2 years from the date of purchase its still under warranty.
Bushnell repair center
8500 marshall drive
Lenexa, ks 66214
# 800.423.3537
$50.00 for alignment
$15.00 if the LCD needs to be replaced
$15.00 for all other maintenance performed.
Oct 08, 2009 | Bushnell PinSeeker 1500 20-5103...
How to use the reticle in my Fujinon Mariner Binoculars?
How to use the reticle:
The vertical scale (reticle) visible through the left half of the binocular, above the compass display, allows you to calculate distance to an object if you know its height, or to calculate the height of an object if you know its distance from you.
Each mark on the vertical scale has a value of 5 MIL (1Mil is equivalent to an angel that can determined an object one meter in height at a distance of 1000 meters). Therefore, if a navigation chart gives the height of an object, by sighting on it and counting the number of MILS, you can determine how far away it is.
To Measuer distance when height is known:
Object Height(m)/Scale Reading x 1000m=Distance in Meters
To Measure height when distance is known:
Distance(m)xScale Reading/1000=Object height in meters
Jan 26, 2009 | Fujinon Mariner WPC-XL Binocular
Double image
The distance between the centers of the eyepieces of your binocular must be the same as the distance between your pupils. This distance is adjusted as follows: 1. Focus on a distant object. 2. Pivot the two halves of your binocular farther or closer apart until you can see a single unobstructed, circular field of view. Make sure to focus on a distant object when you do this because when you focus on a close object you always see two slightly overlapping circular fields. Your binocular may have a scale on the top, between the eyepieces, to help you remember this setting.
Aug 03, 2007 | Bushnell 10 x 42mm Sportsman Binoculars
Double vision
Jul 03, 2007 | Bushnell Powerview - Compact 10 x 25...
Focusing Difficulties
1. Typical problem subjects for autofocus 1) Very low-contrast subjects 2) Overlapping nearby and distant objects 3) Very bright subjects in the center 4) Subjects moving very fast 5) Subjects through glass Focus on an object that is at the same distance as the desired subject, apply Focus Lock, and then recompose the picture. Or set the lens focus mode switch to (or), and focus manually. (Manual focus is only possible with cameras providing this feature.) 2. Attempting to take pictures out of the camera's shooting distance: When taking pictures out of the camera's shooting distance, the subject will be out of focus. The shooting distance differs from each camera model. Please check the specifications of your camera in the instruction manual to determine the shooting distance.
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Optics Logo
Top The Optics Experts
David Clark
David Clark
vince
geob91
Are you a The Optic Expert? Answer questions, earn points and help others
