It is a Samsung LED series 5000 flat screen, two years old.
Https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
wholesale Samsung BN44 00715A L55G2Q ESM PSLF151G06A Power Supply Used
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
