Question about Building Materials
Genie Blue Max opener has become very noisy. I lubed the screw, but it didn't help. Is there someplace else on the opener that requires lubrication?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 25 Answers
Check for loose fittings or connections. Vibrations will cause noise.
Posted on May 02, 2017
Replacement motor bearings for a genie shop vac/blower model# pb 15
Unfortunately those machines do not have serviceable bearings. The entire motor needs replaced. However, I have saved noisy bearings by putting oil on them, specifically 3 in 1 Blue Label motor oil. A few drops spread on the top and bottom of the bearings and giving the motor a few backward and forwards turns by hand will help those bearings immensely.
Feb 20, 2016 | Genie Company Vacuums
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
Unable to program universal opener with genie pro max garage
Actually, this remote can be used with Genie Garages. See the article here on eHow - I used this to program a KLIK1U to work with my Genie Promax 2 garage. Hope that helps!
Oct 11, 2012 | Chamberlain Clicker Universal Remote...
Noise while in use
First, check the ramp area. A ramp with worn groove marks can become quite noisy. It could also be coming from a bearing in one of your wheels. If the noise seems to be coming from the rear of the machine, attempt to lubricate the moving parts and the different connection points. Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
May 29, 2012 | Precor EFX 546i Elliptical Version 4
How/where do you lube a 10 year old 1/2 HP Chamberlain garage door opener to make it run quieter?
First thing you need to do is determine if it is the opener or the door that is making all that noise. The door is usually the culprit and you can lubricate the roller bearings and each pivot point of the door with silicone spray. Do not use grease and do not lubricate the channels that the rollers roll in. Some WD40 on the springs will help them live longer. The only place to lubricate the opener is the rail if it is a chain drive. Use lubri-plate on it. The screw of a Chamberlain screw drive opener does not require lubricant.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Runs but noisy
Look in the drum. If you see 3 screws in about a three inch circle in the center of the back, then it rotates on a ball and socket. These get dry and or loose. You can try greasing it with a very high temp grease (try one for lubing disc brake calipers on cars) or it may need to be replaced. If you don't see those screws, it probably runs on rollers which either need spray lube (such as WD40) or replacing.
Nov 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Opener only raises the door one foot.
IF THE DOOR IS BALANCED TRY ADJUSTING THE SENSITIVITY.
THE DRIVE SHOULD BE LUBED WITH WHITE LITHIUM OR GENIE LUBE 2 TIMES PER YEAR TO KEEP THE UNIT QUIETER AND PREVENT EXCESS WEAR.
IF YOU USE THE WRONG LUBE - GREASE ETC. THE UNIT WILL GET GUMMED UP AND WILL HAVE PROBLEMS IN COLD WEATHER.
ONCE YOU ADJUST THE SENSITIVITY YOU SHOULD BE OK.
Aug 24, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Building Materials Logo
347 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
