Question about Cameras
Cool shot 40 no longer gets power - Cameras
Refrigerator runs too long.
Thank you for contacting
There are various reasons why a refrigerator keeps on running.
The motor will run longer under warm conditions or if the refrigerator is receiving direct sunlight from a window or door. At normal room temperatures, your motor will run about 40% to 80% of the time. Under warmer conditions, it can run even more.
A recently installed refrigerator will initially run more while cooling. Allow 24 hours for the refrigerator to completely cool.
When large quantities of food are added, the refrigerator has to run longer to cool the new items.
The motors will run longer when the doors are frequently opened. Conserve energy by getting all items out one at a time, keeping food organized, and closing the door as soon as possible.
Also a worn door seal or gasket in refrigerator or dirty condenser coil can be the reasons for refrigerator to run long.So you need to consider all these factors troubleshoot your problem to your refrigerator.
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | GE Refrigerators
I cant get my camera to turn on. thanks for your
Fist charger your SONY Cyber-shot DSC-W120 battery and clean the connect place of the battery and camera. Please make sure that the battery has been charged by the Sony Cyber-shot DSC-W120 charger. Li-ion batteries life is about 2-3 years, and if you have stored your battery with no power for a long time, the battery maybe has been damaged. When store Li-ion batteries you should charged it at about 40% first.
May 06, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
My Rancilio Silvia, about three years old, does not seem to be generating sufficient pressure. Standard espresso grind requires about two minutes for a shot and coffee is bitter. Is there any way to...
First things first, remove the screw and shower in the head and clean. Then change grind to something a little coarser, since we are testing the machine we will not tamp the coffee(we are doing this to have a constant in our coffee brewing equation). Note how long it took to brew, if it brewed longer than 40 secs, then adjust grind and try again. If coffee shots looks better and taste better then we are on the right track, we are looking for any thing between 15 and 30 sec depending on the coffee blend from light to dark. If you are getting the same results over 40 secs for a shot no matter what grind you use then the pump needs to be replaced.
Nov 28, 2010 | Rancilio Silvia Espresso Machine
How many hour i freeze my hard drive?
1 hr is probably enough. Even if you freeze longer, it will heat up real fast once you start the recovery process. Get a small plastic cup, put ice in it & set it on top of the drive to prolong the cool temp. Keep an eye on moisture build-up.
Jun 02, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
I have a Cool Pix 5700. Taking longer to advance to next shot
If you have changed you media card, that could be the problem.
Not all media cards are the same! Some are faster then others, try up-grading your media card!
Apr 17, 2010 | Nikon Coolpix 5700 Digital Camera
I'm using a red dot scope on a mossburg turkey gun with a choke. I'm using the 3'' heavy tungston loads for longer distance shots. What distance should i zero in the scope at? 20 yards? 30 yards? 40 yards?...
I set my sights for 30 yards.40 yards is a long shot because you always aim for the head when hunting turkeys.Good luck with the Mossberg.I traded mine for a Remington.Still got a Mossy for a "loaner" or a backup gun for a client.The 3.5 magnums are simply too punishing to the shooter.
Mar 08, 2009 | Optics
Warm air
sounds like you have an under charged system. this could be due to a lose of refrigerant ( a leak ). Keep in mind this is the most common problem. I would have a local shop add some refrigerant to it, make sure they have the ability to do a leak and a pressure test.
Jul 02, 2008 | Mercedes-Benz CLK Cars & Trucks
Insignia 30" HDTV
Jul 02, 2008 | IBM FRU POWER/RESET CARD 73P6310 Power...
Does it really cool to 40 degrees
Many of the beverage coolers that run on the 'solid state' principle will work...provided the temp in the car is not more than 70 degrees. You can get one at any auto supply store for 40-100 dollars.
Nov 03, 2007 | ThermoKool MR-138
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
