Question about RCA Audio Players & Recorders
I have an rca 5 disc stereo. My son removed the cover to figure out how to get cd drawer to open. Now I can only have sound if I use headphones. What did he do????
  • Janet Davis
    Janet Davis Apr 26, 2017
    Well I opened it up wiggled wires pushed plugs and no good. But now I noticed the cooler fan is not running but getting very hot. Should I just give up and chuck the whole thing???
    Top Expert:
  • RCA Master
  • 44,949 Answers
Some of the wiring may have been disturbed or connections broken during the investigation.
Posted on Apr 26, 2017
  • Janet Davis
    Thank you now to try and figure out which ones.
shanth
  • 108 Answers
SOURCE: CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Posted on Dec 22, 2007
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
Eagleeyes
  • 199 Answers
SOURCE: cd player
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Posted on Feb 24, 2008
SOURCE: cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Posted on Jan 20, 2009
SOURCE: We have the RCA RS2767i
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Fred
Posted on Mar 06, 2009
Cd drawer came out
Wow , mine did the exact same thing . I don't know how to fix it . How weird is this to even happen. CD drawer just comes out, go figure ?!?!? Did you ever resolve ?
Nov 28, 2013 | Sharp CD-DH950 5-Disc Compact Stereo...
My 2001 RCA 5 CD Disc Player won't open and makes a continuous motor sound. I thought a cd was stuck, I took the top cover off and removed the offending disk. However the problem remains. The player
Five disc players often develop indexing problems. While you have the top cover off, first read and heed the laser warning then you can watch the mechanism spin around merrily trying in vain to find a home position. You also can insert a disc in a random position (say number 1) and watch it be unable to locate the disc and display the location correctly.
Nov 21, 2013 | RCA RP8070D 5-Disc CD Changer Disc Direct...
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
How to connect speakers to RCA model #RP-8070D
This unit is just a 5 disc CD player and cannot drive large speakers all by itself. Normally it is hooked up to a stereo receiver / amplifier which is what provides the power to drive the speakers which are wired to the back of the stereo amplifier.
If you have a home stereo, then just run the cables from the 2 AUDIO OUT connectors on the back of your CD player to the CD IN connectors on the back of your stereo.
Then turn your stereo on and select CD on your stereo input mode selector and you should be able to play the cds on your RCA and hear them through the stereo speakers.
If you do not have a stereo amplifier with speakers to connect it to, then you can always listen to it through headphones connected to the headphone jack.
Or if you have a set of self powered amplified speakers, like the kind you hook up to a computer, then you can run the AUDIO OUT cable from your cd player into those as well.
Good luck.
Apr 14, 2011 | RCA Audio Players & Recorders
My RCA Stereo system 5 disc cd drawer keeps opening. When I put a cd in it, the unit opens and keeps opening. It only stays closed when I turn off the unit and manually push it closed. What could be...
These units are actually nice units. There is a "loading belt" inside that controls the tray movement as well as the final "load" of the mechism into the play position. If the load does not complete, the unit will "eject" or open up. This is most often cured by replacing the loading belt. This is a common problem with any rubber component. As it ages, it gets a little slippery and thus will not have the grip to complete the loading sequence. The belt for this will run about $5.
Dan
Aug 26, 2010 | RCA 100-Watt Stereo System With 5-CD...
The cd door is stuck as if a cd is out of place. Won't open enough to see the problem.
Before, when trying to see the problem, I clicked "skip" to see if it would go through all the discs. It did, but still wouldn't open the door. Later, I clicked "play" each time, then "skip", and after going through all 5 discs, the door opened. Go figure.
Dec 19, 2009 | RCA 100-Watt Stereo System With 5-CD...
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
Cd changer drawer won't open
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Nov 26, 2007 | Panasonic Audio Players & Recorders
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
