How do i know if the picture tube is blown? my panasonic ct32hl44 just wont turn on, via remote, or manually hitting the on switch
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
If tube is dead it will turn on just wont have a picture but will have sound
sounds like you blew a fuse inside the unit
open rear cover and look on the left hand side wile looking at it from the rear
REMEMBER THERE IS HIGH VOLTAGE INSIDE A TV
ALLWAYS WEAR RUBBER GLOVES LIKE FOR WASHING DISHES
this will limit the shock if any and posibly save your **** from a trip to the morgue the fuse is 1 inch long and round usualy glass and probably blowen if not then it's a reley or a board problem if it aint the fuse then it's proably time to buy a new tv
they are cheep on craigs list if all else fails
Posted on Jul 25, 2009
Just bought a new Panasonic TC-L42U22, connected it to a samsung time warner HD cable box via HDMI, but the cable remote is not working. There's picture and sound, but can't turn it on or off, change the...
You have to program the remote to work with your specific model tv. If it still doesnt work after that call your cable provider and ask them for another remote.
Mar 24, 2011 | Panasonic TCL42U22 42 in. TV
Panasonic CT32SF wont turn on
Dont know spec of this model but if it has a CRT (glass tube) display rather than a LCD one, clicking at switch on is idicative of a power supply overload which, 99 times out of a hundred on a CRT telly is down to a fault in the power supply itself or the line output stage (the bit that generates the very high voltages in CRT tellys and also makes the picture scan left to right).
In short, not a DIY fix - take it to a repair shop.
Sep 07, 2009 | Panasonic CT-32SL14 32" TV
How to make tosiba tv show the movie that is playing on a tosiba
You may need to manually switch the input on your tv via the menu on the front panel switches if your universal remote does not have an input button or it just wont respond.
Aug 25, 2009 | Toshiba 27AF43 27" TV
We have a blue screen, what do we need to do to get the TV back o
hit the input button on the remote,once or twice to get picture.or it may be labeled audio/video
May 09, 2009 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
RCA Colortrak Stereo Monitor won't play DVD/Nintendo
The way you describe having your TV/DVD connected you wont see the picture in the regular channel line-up.
You will have to tell the TV to to switch to the video input. This is usually done by navigating the menu to the "input" and selecting video 1, video 2 etc
Failing that try changing to channel 00 ( just type 00 in remote)
Some sets will allow you to type in 02 and then hit the channel down button on the remote.
If you have the user manual it will give you the exact steps you need to take.
Mar 13, 2009 | RCA F26317 TV
We have a large tube pansonic wide screen tv. it sometimes would stay in standby mode and would not turn on when using the remote or channel switches on the tv.. this is getting worse to the point where...
This fault can be caused by low secondary supply voltages often caused by the value of capacitors becoming low and requiring replacements but you will have to have a technician.
SUPER8
Dec 01, 2008 | Panasonic Televison & Video
SET UP VIERA LINK PANASONIC PT960
Can you explain a bit more please. What exactly is the problem? Are you getting any picture or audio through to the TV? Are you getting any picture or audio through to the home theatre? Have you got the home theatre setup via HDMI? Have you connected the audio from the cable to the home theatre via optical or phono? What model is your LG LCD HDTV?
I already have the manual in front of me for your home theatre system. If you can give me some more information I can help you out.
Thanks.
Nov 30, 2008 | Panasonic Home Theater System System
Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Jan 19, 2008 | Televison & Video
Picture tube doesn't turn off
The power relay driver or the relay itself is bad. Its sticking closed so the voltage is there for the power supply but the micro has turned off the tuner.
Sep 15, 2006 | Panasonic CT-27G23 27" TV
Televison & Video Logo
912 people viewed this question
Top Televison & Video Experts
