Question about Electrical Supplies
I dont have power to gen - Electrical Supplies
I have a third gen acura tl and I need to find out with fuse controls my speedometer, any help?
the fsm covers that
as does alldata.com
why not post the SYMPTOMS, then say , what can cause this and what tests can i do to find it.
this is called DIAGNOSTICs, all else is guessing.
if that costs too much , buy a DMM meter and use ohms scale
to test every fuse in the car. a $10 meter. at walfart works.
in most cars the same fuse that powers the speedo , powers them all in the cluster.
so?>?? is the speedo dead, stuck, jerking, or what.
and what year car, dont tell me gen, tell me the YEAR>
cars vary by year, engine and country.
so...????????????????????????????????
Jun 15, 2014 | Cars & Trucks
Charging system voltage
connect a pair of jumper cabells to the gen connect the pos to the gen side of the gen and the negative to the feald side and hook them to a hot car batt momentarley do not do wial running . should stop probleam good luck
Aug 05, 2013 | 1979 Harley Davidson XLH 1000 Sportster
I'VE got a coleman powermate 5500, i've got no output from the plugs. i've tried the circuit breakers. is there a fuse somewhere?
There is no fuse. Most common problems are loose connector from panel to gen set, worn brushes, faulty rectifier board or needs to be spiked (more serious reasons but lets not go there). Brushes and panel easy to check, remove cover to gen. and look at brushes for good contact to com. rings. Remove rectifier board from mount and look at capacitor for leaks or swelling. Replace as needed. Parts are available at jackssmallengine. com There are many ways to spike gen. as seen when you google the subject, however I just use a one amp 12v battery charger (or any small dc power supply 1/2 amp to 1 amp) and very quickly/split second contact brush connector while engine is running. Mind polarity, you must know which brush is positive. Usually on coleman the brush closest to bearing is positive. Spiking works immediately, if no joy, more serious problems exist. Dont worry, you cant break anything doing this, remember it is already broken. Post again if you have other question. Good luck
Sep 08, 2010 | Coleman Electrical Supplies
Digital Inverter Generator XG-SF3600 running but no current
i have the same problem. I have AC from the windings but nothing leaving the inverter module..Its a sealed unit. There is virtually no parts back up service & if you can track down parts, they are quoting from $ 400 to $ 700 for replacement..If you expect this gen set to last like a honda or yamaha your mistaken..Dont buy chinese unless your short of folding stuff or you only use your gen set occasionally & for those that have had no trouble with theirs, its only a matter of time. trust me, they are a disposable item..
Sep 06, 2010 | Electrical Supplies
I have small portable generator with 220 vac in the philippines and a 12amp 12 v ac to dc converter. can i connect my 1000 w inverter to produce 120 vac becouse i dont have the batteries yet to run the...
no these are made to run off a batteries the 12 volt supplied from the gen is for charging batteries only and if the engine for starting the gen set has a battery their usual to small to run then their made for car style batterers.
hope this helps
Aug 14, 2010 | Vector 2000w Power Inverter
I got a 1st gen 1 gb ipod nano and i dont know the lock pass
to sync it you will loose what is on it. if you want your own stuff on there you can set up an itunes account with paypal and not have to use a credit card. This is the only way around the security
Dec 16, 2009 | Apple iPod nano
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
