Question about The Health & Beauty
Ihave a lark 1 scooter and need to know how to hook up the batteries, on 1 battery it had 2 black wires, on the other had 1 black 1 red
    Problem Solver:
  • 9 Answers
Should have had 1 red =+. 1 black = -, red positive. black negative
Posted on Apr 26, 2017
Lark 3. Where can I get a wiring diagram?
hi , you won't get a lark 3 diagram sadly
If you tell me the controller used or better a picture (black box located at the rear ) i can help , sometimes it hard wired by a switch from batteries or the controller outputs a voltage to the lift motor ,
I have repaired many Larks...
Regards
Rob
www.gewizrepairs.co.uk
Jun 08, 2015 | Health & Beauty
How do i change my wiring for my autogo 550 to adapt it to a trickle charger. it now has 4 wires , I need 2 wires?
this scooter uses lead acid batteries
this type of battery much like a car type
uses constant voltage
like 13,8v from a car alternator
so a trickle charger is no use and wont work
as it only provides a constant current and not a constant voltage type senario for the charge up
use a car battery charger
problem solved for about a fiver....
the scooter will need eather 12v or 24volts
so you need either a car charger or a truck battery charger
at least 15 amp @ 13.8volts...
Sep 14, 2014 | Radio Communications
Charging schematic for pride scooter
red + goes to pin 1, black - goes to pin 2 and jumps to pin 3
Dec 29, 2013 | Pride Rally 3 Wheel Scooter
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
I have a pride go go elite traveller 4 and need some new batteries, but what batteries and connection am i looking for?
Rachel you need 2 12/12AH batteries that are located in the battery pack under the seat. Simply pull the battery pack from the scooter and with a standard phillips screwdriver remove the many screws attaching the battery pack together (simply turn the pack over to get to the screws) There will be two wire on each battery and also a heat sensor attached to the side of one battery remove the wires from each battery and carefully reove the heat sensor. You can bring one of the batterys to your local battery warehouse type store or a provider and purchase 2 new ones reinstall like you removed attaching red wire to red terminals and black to black terminals and reattach the heat sensor to the side of one battery (you can use packaging tape to reattach). replace all the screws to put the case back together and reinstall in your scooter. Charge the batteries with you charger until the charge light is green then happy riding HOPE THIS HELPS
Aug 20, 2010 | Pride Mobility Products Go-Go Elite...
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
Model# RR100 MFG Code 27046B, got 2nd had with no manual. How do I hook up the new batteries? So many terminals to choose from?
Hi.The best idea if you are not to sure, is to get help. If you want to do it your self, be careful, batteries can be dangerous if shorted out.
Each battery has a positive ( red ) terminal, and a negative ( black ) terminal.
Change one battery at a time, make sure the scooter is turned off and /or unplug the battery leads.
The red wire will go to the red terminal ( positive ) onthe battery, the black wire to the black terminal.
Each battery should have 1 black wire and 1 red wire to it.
Remember, be careful.Neil.
May 30, 2010 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
47 people viewed this question
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
