Question about Garden
Fix lawnmower deck on 46 inch 21 horsepower rear tension pulley spring.
2 Suggested Answers
  • 40473 Answers
SOURCE: Troybilt 46 inch deck model no. 14at809h766 rear spring tension pulley. See illustrations.
For this kind of information, contact Troy-Bilt directly.
Posted on Apr 26, 2017
Apr 26, 2017 | Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
A diagram of deck belt on deck 46 inch cub cadet
Look here then when you put in your Model number look under ATTACHMENTS for a parts diagram showing the Belt layout
Jul 27, 2014 | Cub Cadet Garden
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
I have an Exmark walk behind commercial lawnmower which is stuck in high gear. How do I fix it?
if it is the older style that has a pulley to change sizes not a trans then look at the pulley with the coil spring on it they get stuck take it apart to clean the sliding area careful the spring has a little tension on it
Is there a way to tighten the deck belt? i have gone through 2 belts and they dont seem to be tight around the pulleys.
Your deck should have a couple "idler" pulleys on them in addition to the main mandrell pulleys that have tension on them via springs to keep tension on your deck belt. Maybe you need to really examine the condition of those "idler" pulleys and also the main pulleys to find the problem.
Sep 10, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Cratftsman Lawnmower; 16.5 horse; 42 inch deck, need assistance replacing armbrake and tension spring #58 on sears schematic; MOwer model number is 917271120-- particularly, where does this spring attach?...
Judging by the diagram the spring mounts under the armbrake, the Bolt (#52) goes through the circular spring. One end of the spring goes into one of the holes near the bolt on the armbrake and the other ( after providing tension by turning the spring ) must attach to a non moving part on the deck to be able to provide the required tension Look for a small turned up piece of metal with a notch in it on the housing.
Hope this helps
May 18, 2011 | Garden
How to put a belt back on a cub cadet lt1050 lawnmower
Take the belt and apply axle-grease to it alllll over. apply large amounts of grease to each pully - and then just slide it on.
May 31, 2010 | Cub Cadet Street Sign- tractor lawn riding...
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
