Question about Galaxy Computers & Internet
Somehow my keyboard on my galaxy tab a is now half the width of the screen and timy. I have gone and adjusted the size in the settings but it isnt changing size when i go to type in any apps.
  • 105 Answers
SOURCE: screen width unadjustable
Most likely width control circuit has developed a problem. Most common causes are a failed diode in the yoke return circuit or open capacitor near the flyback.
Posted on Sep 24, 2006
SOURCE: Zebra TLP2844 Prints Centered and Half the Width
create a word template document with the page size the same size as the label. Set the margins to 0 and fill the label up with text. This should make the printer print right the way over the bale.
Posted on Jan 27, 2008
  • 20 Answers
SOURCE: picture size
are you using a dvd player when it happen?
maybe the settings in the dvd player of from the source of the video unnoticely turn to that set up.
Posted on Dec 10, 2008
  • 4889 Answers
SOURCE: keyboard disabled. somehow disable my keyboard
Did you try Fn+F5? You can usually disable the touchpad but keyboard?
Try to uninstall the keyboard from device manager. Right-click on my computer->Properties->Device manager-Right-click on keyboard(HID keyboard device) and uninstall it. Then reboot your computer if you just disabled it windows will re-install the driver automatically and re-enable it
Let me know if you need more help.
Posted on Jan 29, 2010
  • 87 Answers
SOURCE: image set up of screen is only half of the monitor
If you v-size is already at 100% then the issue is with the picture being sent to the monitor. Based upon what kind of input you have for the monitor there is a number of different ways to fix this. I will assume you are using the monitor with a desktop computer. If this is for XP, then there is a simple fix as follows, adjusting your display properties:
Right-click on your desktop background and then click on "Properties" this will open up a new window. Select the "Settings" tab, then drag the green arrow in the "Screen Resolution" field to the desired setting. Since you have a "widescreen set-up" you more than likely have a resolution where the first number is about twice the second number...they should be close to even to have a square image (bigger numbers show more detail than smaller numbers).
Hope this helps!
Posted on Jul 16, 2010
The keyboard on my Samsung Galaxy S4 has shrunk to about half its size, and moved from the bottom to the middle of the screen. How can I fix it?
have you tried the fingers expansion to enlarge it ---the opposite to the pinching action to reduce the size of something
Nov 02, 2016 | Samsung GALAXY S4
I have a Samsung galaxy tab 3 sm t210, can i connect it to my television
Yes, you can either "cast screen" using the TV settings as well as the Tab button (providing your TV is fairly modern and with that feature)
But the easiest way is to buy a HDMI cable with a micro HDMI/USB from your phone on one end that converts up to the standard size HDMI...plug and play (just adjust the input port on your TV menu)
Oct 12, 2016 | Samsung Galaxy Tab 3 7.0" - White...
Which service manual setting controls horizontal size?
You're discussing about the factory mode adjustments. The horizontal width adjustments will not be there. You have to adjust it by replacing certain capacitors at the horizontal output stage.
May 18, 2013 | Panasonic CT-20G6 20" TV
I hv lg 700s studioworks crt monitor... i hv set a resolution of 1280*1024, but now m not able to control some of its functions like its width size...width has gone out of the monitor, it isnt getting
Select reset option by monitor menu, set it to default first. Then try to adjust the width and height of the screen. If this does not help you, try other resolutions set by the system.
Nov 26, 2011 | LG Studioworks 700S 17" CRT Monitor
How do I adjust web page to fit display screen
There is the Zoom option in the View menu if you are using IE. You can set it to 100%. With IE8 you can use F11 to set it to display on full screen. Unless you need to set the screen resolution, width and height for your monitor, those should work for you. Pressing Ctrl key and scrolling your mouse will adjust the zoom of web page too, quicker way.
Aug 18, 2010 | Microsoft Windows XP Professional
Text Message Font Size
Well, WM allows you to adjust text size in general, I'm not sure it will effect the text messaging application, but, you could give it a try. Go to 'Start > Settings > System tab > Screen > Text Size tab' and adjust the slider to your needs.
Hope it can help you out, somehow.
Cheers! Carlos
Apr 24, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
My dell laptop/windows xp now has a half-size, upside down screen
Hold down CTRL and ALT keys and press UP arrow to turn it back to normal. For the screen size, right click on an empty space on Desktop and select Properties then go to Settings tab. On screen resolution move the bar to adjust the screen size to your desired one.
Jul 12, 2009 | CMS 250GB HARDDRIVE 2.5 DELL INSPIRON 500...
Monitor is enlarged, wont return to normal size
Hi, three possible things. 1) You have activated the magnifier. Go to Start, All Programs, Accessories, Accessibility, Magnifier - deactivate, should be a small window bottom left of the desktop. or 2) Your screen resolution somehow changed. Right click on any clear part of the desktop, go to properties, Settings Tab. Adjust screen resolution to desired setting then click Apply/OK. or 3)You are in Safemode. Restart and if same large icons etc, do # 2. Hope that this be of some help to you. Pls post how things turn up. Regards
Apr 27, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
32 people viewed this question
Top Galaxy Computers & Internet Experts
Chance Miller
Brian Anderson
Are you a Galaxy Computer and Internet Expert? Answer questions, earn points and help others
