Question about Boating
I have a 1989 evinrude 175xp, I just put a cap on the fuel sileonoid and need to know which way the orange arrow needs to be pointing.. My boat idles fine, but loses power when I try to go on plane..
  • 1673 Answers
SOURCE: omc specs
You will need to repost this in the correct section, this one is for vacuum cleaner repairs.
Posted on Jul 13, 2008
  • 77 Answers
SOURCE: Chrysler 70 HP outboard motor dies when pushing throttle
I have found that 99 percent of the time when this happens it is carb related. It is very possible that you picked a a small piece of grit or trash in the high speed jet of one, or both, of your carbs. I would be willing to bet that pulling the carbs and cleaning them will resolve your problem. I am almost positive that will fix your problem, mainly because it sounds like you've already tried everything else. I had this same problem last season, and what had happened was I left the vent open on my fuel tank, we got a shower, and I pulled just a small bit of water into the carb and that was it, she would not do anything over idle until I pulled the carbs and cleaned them. i even put the water muffs on it and let it run in the yard for about an hour thinking that it would burn the water out, but i was wrong. Anyway, clean the carbs and i think you'll be in good shape, Good Luck.
Posted on Aug 02, 2009
  • 5651 Answers
SOURCE: boat won't plane
Check your prop hub. If you have a larger motor there are rubber bushings in the hub which can slip. This is a safety feature like shear pins. You may need to rebush the prop.
You also need the proper length motor for your transom. And you need enough power to overcome the drag and weight of a loaded boat. Check and see if the angle settings for the locking pin will provide an upward thrust to the hull and not plow the hull down.
Posted on Mar 17, 2010
  • 49241 Answers
SOURCE: How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Posted on Apr 25, 2010
  • 5 Answers
SOURCE: no spark on my 1989 evinrude boat motor
No spark on any? My guess would be a power pack it is common for that motor check to make sure the tether is on
Posted on Dec 03, 2012
Evinrude 60 hp tracker dies below 1100 rpm, will not idel. cleaned carbs. didnt help. runs great under throtle. compression on all 3 cylinders 121 to 125. why cant I get it to idel.
the idle circuit in the carby still has a blockage that is preventing it from allowing the fuel through
compression is good
possible that the ignition timing is not correct
at this point I would suggest that the carby be overhauled by a Evinrude service shop as rubber from hoses , fuel pump breaks down and fine particles get into jets and passages and block up the holes
Nov 21, 2017 | HP Boating
Getting water in carbs not from fuel tank it happens when I put it in forward it's a 140 evinrude looper
Your engine should be sealed enough to prevent this..unless you have the engine mounted so low it idles under water...???.. There is a seal that goes between the lower cowl pieces and the engine, a seal around the engine cover(cowl)...and seals that surround all wires and cables.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Jul 14, 2017 | Boating
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
70 HP evinrude 4 stroke outboard (pontoon boat). New spark plugs all connections good. Will only do idle speed put I. Forward or reverse won't gain speed
I had the same problem with mine, let me see if I can find the picture I took.
Just above the red arrow on the choke, the linkage has to be firmly clipped in that little black clip. Unless that is in place, you are only throttling one carburetor! Drove me crazy trying to find the answer to that one and it happened after the marina engineers had replaced a leaking fuel hose. Mine was a two stroke, but I bet the linkages are the same to the carbs.
May 02, 2015 | Boating
1996 Evinrude 9.9hp, 2-stroke power loss.
Checked the vent cap on the fuel tank?
Check if it runs again great after pumping fuel...
Check when it drops power if both spark plugs still sparks...
You can have a bad coil or cdi...
Jul 25, 2017 | Boating
Evinrude "high thrust" 1998 model just bought boat
Hi, replace the sparkplugs and the carby(s) will probably need stripping down and cleaning as stale fuel leaves a residue in the bowl and jets. Hope this helps, regards Phil.
May 31, 2011 | Yamaha Boating
I have a evinrude 48hp 2 cylinder oler model, that will start when you cover the carbs, but will not idle regularly, but full throttle it will run misty
You're not getting enough fuel. Check if there is a fuel filter than needs changed or if your gasoline is contaminated.
Sep 23, 2009 | Boating
1989 200hp evirude wont idle in water idels fine out of the water
I would readjust your idle mixture screw with engine in gear and on the water at an idle. That is a common problem after rebuilding carbs. It will run diferently under a load in the water. Just tie up to the dock and adjust them there.
Jul 11, 2009 | Boating
Engine will not stay running unless i pump the ball...
Going to sound silly, but is the fuel filter properly installed? I've seen this happen when the fuel filter was installed upside down. In other words, the arrow showing flow of fuel was pointed in the wrong direction. If the fuel ball is collapsing, it could be a vacuum lock problem. Try it with the gas cap loosened and see if that helps - it could be 'too airtight' and creating a vacuum, which cuts off fuel supply.
Jan 05, 2009 | Boating
Boating Logo
37 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
