I have the dvdr3475/37 and I've tried to record on both -r and +r they both say it can't record on +r discs. This is ridiculous. Please help
Samsung DVD-R4000 not recognizing DVD-R discs
As a last resort you can try a firmware update if there is one but don't hold your breath. Unit may simply have lost ability to record and not be able to playback. Not uncommon - happens.
Sep 14, 2017 | Samsung DVD-R4000 DVD Recorder
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
Am in process tranferring vinyl to cd using sony compact disc recorder and not computer,ran out of audio discs last week purchased some verbatim discs high speed rw but will not work on my machine can you...
Hi raymackie265
You are right , don't use cds for computer ( cdroms ) but well audio cds . Pay attention to this point when purchasing new stuff . Regarding the issue with cd-Rw , it's a compatibility issue with your Sony device and you need to check if the recorder will accept CD-RWs . If yes ( and it should be yes ) , try to find lower speed discs but you need to find audio cds . I ' m using a Pioneer recorder and it works fine with any kind of audio cds , not with cdroms .
Best regards ,
fanaudi .
Aug 30, 2011 | Verbatim 10PK CDRW 80 MIN 700MB 4X12X...
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have just put a blank disc into my sony mds s40 to record but now nothing works on the player....i just keep getting a small red flashing toc, i've tried unplugging from mains then re connecting but...
You may have the disc shutter closed preventing recording. You should never interrupt the recorder when it is trying to write to disc, you probably corrupted the table of contents (TOC) on the disc and need to reformat it to use it again.
If your deck is older you may have worn out the recording heads preventing it from writing to the disc in the worst case.
May 07, 2011 | Sony MDS-S40 Mini Disc Player
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD will not recognise discs
I think that moisture has formed on the boards.
The best thing to do is to take the recorder
and put in a warm room,connect it and leave for 2-3 hours.
Then try with a disc again.
I hope i`ve helped!
Nov 29, 2009 | Samsung DVD-HR730 DVD Recorder/HDD...
Disk wont finalize samsung sc-dx103
Samsung support just told me that there has to be some space left on the disc to finalize it. In other words if you fill the disc with too much video, the disc won't be able to write the necassary info on the disc to finalize it. Support told me you needed 10MB to finalize. He also told me to leave 7- 10 minutes of free space which is ridiculous because the disc only records 20 minutes. I have complained to Samsung about this ommission from the manual and that the camcorder should know to leave enough space to finalize the disc.>
Aug 09, 2009 | Samsung SC-DX103 DVD Camcorder
OLYMPUS DS-330 Drivers
Hi Aklas.
Olympus DS-330 voice recorder drivers (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Nov 05, 2007 | Olympus DS-150 Digital Voice Recorder
My dvd recorder no longer records
take your DVD player to a tech and your problem will be all over.good luck
May 17, 2007 | Funai FDRV90E DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
