Question about Craftsman Garden
How to replace self propel drive belt on craftsman walk behind mower
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,283 Answers
They have a cover on the top and bottom of the mower remove both take blade off makes it easier then ease the belt off of the adjuster and just revetrse process to replace
Posted on Jan 04, 2018
  • 744 Answers
SOURCE: toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Posted on Mar 19, 2009
SOURCE: my craftsman rotory lawn mower 6.5 hp self
You have water in in the carborator, I'll bet. I had this same problem. Here's what I did.
I emptied the gas tank, put in a new spark plug, changed the oil and then unscrewed thd big nut on the bottom of the float container (attached to the carborator near the rubber gas injector button) and emptied and cleand the float container. Then i put it all back together, pulled the cord and the same thing happened, but this time i could keep it going by having my daughter constantly pushing the rubber gas injector button. After it had run for a minute with this constant pushing of the button, all the water was gone from everytwhere and it worked.
Posted on Aug 13, 2009
  • 133 Answers
SOURCE: Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
rwvanlue
  • 486 Answers
SOURCE: craftsman self propelled walk behind lawn mower
Normally grass and debris are clogged under the belt/transmission cover, preventing the full engagement of the transmission cable/lever.
The cover is located on the topside, left front corner of the mower shell. Clean debris, try it again. If OK, re-install cover, If not, there is a cable adjustment (threaded portion with a nut on either side of a fastening arm) move the cable adjustment towards the rear, this will tighten the cable. Sometimes the cable assembly (includes the cable and the control box) needs to be replaced
Posted on Nov 08, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
The self propel system slowly stopped working and now doesn't work at all, what could it be?
You didn't specify the make or model of your mower, but generically speaking for self-propelled walk-behind mowers, the drive belt or the front wheel gears can wear out after several years of use. The drive belt could also be loose or off the pulley. The belt and the front wheels can usually be replaced.
You can remove the drive pulley cover and see if the belt is off.
The other components that make up the drive system are the gearbox and the engagement cable. Sometimes the cable can get get out of adjustment or come loose.
Jul 23, 2015 | Garden
Replcing mower belt
Is this a riding mower or a walk behind? If it's a walk behind and has a belt it has to be the belt that turns the self-propelled gear box. Which is it?
Jul 21, 2014 | Snapper Garden
Lawnboy 10665 won't self-propel and impossible to push
If you have the smell of rubber burning the belt isn't gripping. Make sure that there isn't anything stopping the wheels turning like old grass or even a piece of twig. If their clear try adjusting the tension on the drive pully.
Jun 28, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Craftsman self propelled walk behind lawn mower sef propel handle will not engage..the wheels will turn if you hold the handle down but the handle won't lock in........is something broken in the gear box?
Nov 08, 2009 | Craftsman Garden
My craftsman self propelled lawn mower no longer
Sep 04, 2009 | Garden
roundo4
Aug 16, 2009 | Garden
Replacing the self-propelled belt on my Murray mower
Here is the link to the parts list for your mower. Though it doesn't give instruction for replacement, it does show an exploded view of the components:
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-22646X92A-WALK-BEHIND-MOWER-(1999)-PARTS-LIST.pdf
I hope this helps...
Good luck
Jul 15, 2009 | Garden
Toro 20073 self propeled, walk behind mower-how to replace belt ?
4. Remove the blade
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
55 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
