Question about Humax Televison & Video
When i connect the antenna to the humax box i get a message on the screen saying antenna short circuited
4 Suggested Answers
wwjdcgh
  • 114 Answers
SOURCE: Antenna input shorted
contact garmin sounds like a defective unit
Posted on Mar 10, 2009
Obertelli
  • 3006 Answers
SOURCE: the humax keeps on messaging that the antane cable
The Humax PVR-150T will definitely have problems using an indoor set top aerial; this is true of almost all Freeview receivers. Freeview signals are typically hundreds of times weaker than terrestrial transmissions and if you've managed with a set top aerial so far it's been working more by luck than design. I find that most set top aerials are so badly made that they're often faulty when new, but as most tend to flogged cheaply at markets and car boot sales the supply chain has no incentive to improve the product.
There has recently been a national Freeview retune, to complete this correctly your box needs the kind of solid and reliable signal which you cannot get with a set top aerial. Some receivers had compatibility issues with the retune and in many cases manufacturers broadcast OAD's (Over Air Downloads) to update the firmware in the boxes to be compatible. OAD's almost never successfully install via set top aerials.
There is an official list of Freeview devices which are known to have problems with the retune; unfortunately it has not proven to be a comprehensive list. The Humax MG-TU1 is one of those which have had problems and from memory it's closely related to your Humax PVR. The official advice is that you contact Humax directly on 0870 247 8800, but they'll probably instruct you to test your box using the aerial system it's designed to use before they'll be interested in offering further assistance.
Posted on Nov 05, 2009
SOURCE: I have an error message
Is the message still there when a other antenna cable is connected?
Or there is a problem in antennacable circuitcard.
My experience is that the connection itself where the plug goes on to the circuitboard are loose and creating a short cicuit.
I don't know if it helps you it's not a solution but maybe a thing to look at.
Posted on Aug 03, 2011
Problem with watching normal scheduled TV and recording programmes
If you have an indoor antenna connected to that particular TV, a slight reorientation can make a big difference.
Oct 25, 2015 | Humax Televison & Video
Terrestrial antenna is short circuited
In the set-up menu, switch off 'antenna power'.
Jul 29, 2015 | Televison & Video
I need installation instructions for a tivo drt-400 humax dvr
No. There is no tuner in the Tivo . It will record cable or satellite but not off air antenna.
Nov 01, 2014 | Televison & Video
LG 32LC2DB television says No Signal after 30 min
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | LG Televison & Video
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
What does the message 'Terrestrial antenna is short-circuited' mean?
It means that 'Antenna Power' in the Installation menu is switched on when it should be off. This is only required when sending power to a mast-head amplifier.
Sep 09, 2012 | Humax PVR9300T HD DVR
My humax box keeps telling me ive got a short ciruit on my arial
That is because most aerials are a loop of aluminium and have an impedance of 75 Ohms.
Go into the menu of your box and switch off the external antenna power.
That will fix it as you don't need external power on a standard aerial.
Dec 19, 2010 | Humax Televison & Video
Hi, I have a 32LG3000 HD tv with software version 3.47.1. I just bought a Humax FoxT2 HD free view box but when connected via hdmi to the LG tv a message briefly comes up on the tv saying invalid format...
I , would try using another ( alternative connection) from your humax , say the scart cable just to see if it , the humax is ok. then if tv has more than 1 hdmi skt try it too, if still not working retry upgrade firmware route
pete
Nov 11, 2010 | LG 32LC7D Television
The humax keeps on messaging that the antane cable is short circuited. is this an internal problem or a problem with the aerial itsefl
Nov 05, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
Mar 10, 2009 | Garmin GPSMAP 172C GPS Receiver
Televison & Video Logo
26 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
