Question about Dishwashers
My Lamona dishwasher has completely stopped working. I checked the fuse on the plug thinking it might be that but the fuse is fine. There is no power at all.
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
  • 249 Answers
SOURCE: BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
Posted on Feb 23, 2008
SOURCE: Whirlpool dishwasher stopped mid cycle
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Posted on Aug 10, 2008
  • 171 Answers
SOURCE: Dishwasher stopped working..!!..!! please help
Hi crystal245,
I'm Harvey the Master Plumber.
Your problem is: GE Nautilus Dishwasher suddenly stopped working. NOTHING!! it was fine one day then went kaput the next. I checked the plug in and the circuit breaker but still NOTHING
I run into this often. Ends up being loose, broken or burnt ellectrical connection in d/w junction box most of the time. It's under the d/w behind the kick plate on the right or center. Turn the power off first and remove the wire nuts. Replace wire nuts and/or repair wire ends as nessessary. Beyond that you're looking at a bad control board or failed connection in the unit.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 2920 Answers
SOURCE: Dishwasher burning smell now not working
it sounds like the motor may have burnt out
Posted on Jan 13, 2009
Lamona LAM 4400 oven not switching on
may be an internal fuse / wire burnt off oven control as nothing works
Nov 10, 2013 | Ovens
DISHWASHER STOP WORKING COMPLETEY
Check the fuse in the plug socket maybe? :)
Is it switched on?
Aug 16, 2012 | Dishwashers
My frigidaire dishwasher works intermittently. It'll completely stop mid -cycle, as if the power was shut off - then eventually indicate a power failure on the display. Then it wil work fine for a c
Hello Tom Weiss, There are a couple of things to check.
1. Check connection at the dishwasher. It is possible that the wire nuts came lose. Re-tighten and wrap with electrical tape to secure.
2. Check for a small leak from sink or faucet this has also been the culpret before.
Dec 05, 2011 | Frigidaire Dishwashers
My dishwasher stopped working, bought within the past few months, it seems like no power is getting to it. I've checked the breaker and all other appliances in house are fine.
Please provide make and model number of the dishwasher along with some indication of the last cycle it completed before this problem occured.
Aug 30, 2011 | Dishwashers
How do I change or clean the filter on my Lamona 8362 dishwasher ? I do not appear to have been given a user manual Thanks
  • 1 Wait until the dishwasher has completely cooled after use before attempting to clean the filter. Turn the dishwasher off and unplug it from the power supply.
  • 2 Remove the lower dish racks and locate the filter compartment on the bottom of the dishwasher.
  • 3 Unscrew the filter housing and gently pull to lift out the filter.
  • 4 Use a few drops of dishwashing liquid, warm water and a soft-bristled brush to clean the filter and the filter housing.
  • 5 Dry the filter and the housing and reassemble them. Reposition them in the bottom of the dishwasher and turn until locked into place. Replace the racks and close the dishwasher door. Plug back in to the local power supply.
  • Jul 07, 2011 | Dishwashers
    Lamona dishwasher from Howdens. E1 code
    we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
    Feb 21, 2010 | Dishwashers
    Stopped working no power light come on like it's dead.The power supply is fine to the plug and the fuse is ok it just stopped why? is there a reset button anywhere?what would cause this? no hint of a...
    check where the pig tail the plug going into the wall follow the plug wire to the connection at the dishwasher. You will need to remove the bottom panel of the dishwasher at the floor. This access panel allows you to see the underneath of the dishwasher. Where the plug wire (pig tail) connects to the dishwasher it is in a small square box on either the right side or left at the front of the dishwasher. Unplug your washer and remove the cover off of this box and check to see if the connections are indeed connected.
    Hope this helped
    Dave
    Feb 17, 2010 | Dishwashers
    Dishwasher stopped working during rinsing cycle.
    1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
    2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse with wiring harness supplied with it.
    Good luck
    Vlad
    First Choice Appliance
    Jan 05, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
    Whirlpool Dishwasher Not Working
    Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
    May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Dishwashers Logo
    60 people viewed this question
    Top Dishwashers Experts
