Question about Cell Phones
1f86-244,unable to change temp.setting ready changed battries
Can't control temp settings for fridge or freezer
Please begin with a Make and model number found around the fresh food section door. Thank you, John Tripp
Dec 23, 2012 | Refrigerators
Even though the remote has lights on the split system air con. does not respond to the remote. We can operate the system manually but the remote is 'lights are on no ones home'!!
the remote may havce bad battery connections? bad battries? be locked off? remove and replace battries. locate program switch on wall stat. temp set to energy saving mode. set out of temp set up-back mode to run in on-off-on mode non occupied
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Heating & Cooling
Replaced charged battery, turn camera on no response, camera lens is extended, unable to turn on camera, changed battry twince, still no reponse.
if the battery you have put is ocnfirmed to have voltage/current in the desired level then the camera is having a power fault within the set and must be opened up. I would advice that this job be done by a Nikon authorised serivce, get and estimate and decide.
Sep 06, 2010 | Nikon Coolpix 8700 Digital Camera
How do i know when to replace batteries ?
There's no sure way to know when to change the batteries. I'd suggest you change them at least once a year. Plan on it when you do your smoke alarm battery change, which should be done at least annually.
Jan 26, 2010 | Weiser Lock Powerbolt 1000 Lock
I can't change the temp. reading from celcius to regular temp.
Check the manual, you have to hold down Ambiant and the Temp Up button for 5 secs or something.
Jan 15, 2009 | 2002 Hyundai Santa Fe
Broil feature not working
make sure element is getting voltage (120v)
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Locked up
On my Moultrie MFG-DGW 2.1, I was unable to change settings etc... It seemed to be locked at the Date/Time screen. I powered off the unit, removed the memory card. Turned on the unit. Then I could change the settings. I made my changes, powered the unit off, reinserted the memory card, turned the unit back on and it read the card and I could make changes too. This happens from time to time. I just have to follow those steps to clear it.
Hope that helps.
Oct 28, 2008 | Moultrie MFH-DGS-100V2 Digital Camera
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
