Question about The Computers & Internet
Bill nye the science guy -motion - The Computers & Internet
Did Bill Nye change his mind on GMO's
Who is bill nye? This isn't the place to answer your question
Sep 15, 2017 | Cars & Trucks
Why is the air coming out is cold
Because a dehumidifier is actually a air conditioner that runs very 'poorly' The way to get the water out of the air is to have a difference in temperatures ... remember in the 4th grade science class when the teacher talked about the DEW point? That natural law applies here.
Secondly, air i motion generally feels cooler than air not in motion. It is one of Newtons laws (I think)
Thanks for visiting today.
Jan 04, 2011 | Danby DDR586R Dehumidifier
Check to make sure that the front top of the L bracket that shields the ink tubes on the carriage is not rubbing against the inside top front metal edge that is just behind the clear plastic cover. And make sure your rails are cleaned and then oiled with NYE oil. There is a problem with the design of this machine, where there is a bracket on the top of the carriage assembly that pushes the ink tubes towards the inside front of the machine causing unneccesary rubbing.
Jan 27, 2010 | HP DesignJet 1050c InkJet Printer
When a body covers equal distances in equal intervals of time then the body is said to describe uniform motion.When a body moves unequal distances in equal intervals of time or vice-versa, then the body is said to describe non-uniform motion.
Apr 27, 2009 | Edu-Science Edu Science Microscope Set
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Computers & Internet Logo
26 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
