How to remove stand on model number 42pc1da - Televison & Video
TV LG 42PC1DA have the standby light in white color and TV don't turn ON nothing is responding. Some one have an idea to fix it ? maybe the YPSU-J011A power supply ? some capacitor are swollen ! Thx
You have to check its main digital board. It is a very skilled work. Contact any service technician. If you're sound in electronics and if you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 20, 2013 | LG 42PC1DA 42 in. Plasma HDTV
I cannot remove the LCD stand
Hello:
Although you're not providing much information (in the future, please provide a specific model number), normally there are two philip's head screws on the underside of the stand that need to be removed before the stand will come off. Hope that helps. If not, repost and provide a model number.
May 13, 2011 | Samsung Televison & Video
I have a Plasma TV LG model # 42PC1DA. We have perfect sound, but no picture. Tried the contrast, tried unplugging for 30 min. What could be the problem and how much might it cost to fix it?
Did you tried diferent sources from where you get the image? For example you could try to connect a video camera, laptop, dvd or any other thing you could hook it up in your TV and check if there is still no picture.
If the screen is burned it costs the same or a bit less than a new one
Good luck
May 06, 2011 | LG 42PC1DA 42 in. Plasma HDTV
I have cracked screen on my LG 42 Plasma model number is LG 42PC1DA. Is it possible to have the screen replaced and if so how much would i be looking at, Thanks
Call your local authorized LG repair rep.. They would be able to give you an idea of what it is and how much to fix. If it is still under warranty it would be free!
Mar 14, 2011 | Televison & Video
My 42' LG plasma tv model number 42PC1DA-DU monitor is not show but the sound is working. What should I do?
In this case, the defect is in Y-SUS PCB, change it and adjust the voltage that are specified
on sticker attached to plasma module
Feb 25, 2011 | LG 42PC1DA 42 in. Plasma HDTV
I have a 42 LG Plasma TV with a broken screen
NO....You must pay attention to all numbers on the back of the TV. Verify these with your tech or contact your LG customer support for the correct board numbers. If the screen was broken I doubt if you can repair this for less than it cost to replace. The screen for this one runs at about $650.00. Good Luck and good advice!
Oct 01, 2009 | LG 42PG20 42 in. Plasma HDTV
NEED A BASE FOR PLASMA TV
Manufacturer LGE Part Number 3501900014B Description BOARD ASSEMBLY
Aug 20, 2009 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
