Question about HP iPAQ 310 Automobile Navigator
Where is the fuel filter located on a 1991 honda accord
    Sergeant:
  • 192 Answers
Under the hood, passenger side, upper firewall, mounted in fuel line
Posted on Aug 17, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Usualy it is locatred on the fire wall on passengers side
easy way to find it is call the dealer he will tell you exactly wher it is located in your model car
Posted on Jul 25, 2009
1991 honda accord will not start, it's getting fuel and spark but will not start
Could be a weak coil or bad ignition module located in the distributor. I would replace the coil if you have not ever done so then the ignition module. The coils last about 150k miles and then can go anytime after that. I've owned four 90's Hondas and they have all had this problem. If neither of those things work then you may have a bad distributor.
Mar 07, 2014 | 1991 Honda Accord
Where is the diagnostic connector located for 1991 honda accord
Some cars have the fuel filter in the car, others are under the hood. If you can follow the fuel line from the gas tank, you should see where the filter is. You should relieve the pressure before trying to change the filter. ---------------------------------------------------------------------------------------------
OBD2 Auto Tools
Jan 16, 2013 | 1991 Honda Accord
Where is the fuel filter on Honda 1991 Accord LX?
I believe the fuel filter is in the engine compartment
May 16, 2012 | 1991 Honda Accord
91 honda accord has fire spark and compression but still no start.
is fuel getting to the engine ?, can you smell fuel, are the spark plugs wet check fuel flow through the filter is it getting to the filter or coming out of it.
Feb 23, 2012 | 1991 Honda Accord
Is there a inline fuel filter on a 1991 honda accord?
Yes there is and it is located under the hood.
Jan 31, 2012 | 1991 Honda Accord
1991 honda accord wagon stalls at stop.replaced fuel pump,fuel filter,cap and rotor,wires,and igniter.runs great and idles fine but can't figure out why it stalls at stops.Also no engine light comes on and...
if stalling occurs when foot on brake,then chances are you have an air leak,in either the hose from the inlet manifold to the brake servo or a leaking brake servo,as the hose is the cheaper of the two to replace try that first.....
Jul 14, 2010 | 1991 Honda Accord
My 1991 honda accord turnover but will not start sometimes,then a lot of the times it will start and shut right off,other times it will start and run fine . what can be causing this problem?
IT SOUNDS LIKE FUEL INJECTORS. OR FUEL PUMP. START WITH REPLACING A 8 DOLLAR PART. THE FUEL FILTER. IF IT DOES IT AGIAN AFTER THAT. CHECK YOUR FUEL INJECTOR RAIL. IT HAS A FUEL PRESURE VALVE ON IT. PUSH IT IN. IF GAS DOES NOT COME OUT. THEN ITS YOUR FUEL PUMP. IF IT DOES COME OUT. THEN ITS YOUR FUEL INJECTORS. JAKE.B
Jun 16, 2010 | 1991 Honda Accord
My 1991 Honda Accord LX won't start, it is getting not getting any fuel. What is the problem?
Two solutions. One Check for fuel pressure, check for fuel filter .
Jan 05, 2010 | 1991 Honda Accord
1991 need to cange fuel filter.....
On the firewall underneath the vacuum control box. Thats just to the left of the throttle body, behind the black air intake hose. The website below shows how to find and change the fuel filter on a 93 Honda Accord: http://ldsdates.com/blog2/2009/04/07/how-to-change-the-fuel-filter-on-a-93-honda-accord/
Apr 21, 2009 | 1991 Honda Accord
Where is the o2 sensor located on a 1991 honda accord ex 2.2 engine
Further clarification on the O2 sensor location: It is in the exhaust pipe, under the center of the car, on top of the pipe, just aft of the oil filter.
Jul 12, 2008 | 1991 Honda Accord
HP iPAQ 310 Automobile Navigator Logo
48 people viewed this question
Top HP GPS Experts
Are you a HP GPS Expert? Answer questions, earn points and help others
