Question about Yamaha Audio Players & Recorders
I have an Onkyo DX-C390 CD player paired with a yamaha R-S202 receiver. When the cd player is on there is no sound from one speaker. In the tuner mode both speakers work fine. Any ideas??
  • 4234 Answers
SOURCE: onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
Posted on May 07, 2008
SOURCE: Yamaha rx770 stereo receiver
I have the same receiver with the same problem. I fixed it by using a cleaning spray on the inside of the input switch. Deoxit 5 is the cleaner and it took care of the problem.
Posted on Jun 28, 2008
SOURCE: Yamaha DSP-A2070 intermittently fail to output audio to speakers
Probably selector switch when you turn to CD mode. The ball bearings inside the switch make poor connection resulting in intermitant problems to either speaker. Yamaha knows the selector switch is defective but has stayed silent. I've had mine replaced for $144.00 Can and it works AOK now. Different switch of course. I've had my problems with that switch for a long time and it was after a few years that a knowledgeable technician knew of the problem. Poor support by Yamaha! I'll never buy a Yamaha product again nor will my relatives and friends. Do the calculations and assess whether the cost of the switch is worth the value of the receiver. I think it is worth it as the receiver when it works is excellent. It is at a stage now when other problems could creep in though including corrosion on the boards and solder joints so have the technicians do a entire quality check at the same time...
Posted on Jul 02, 2009
larry james
  • 287 Answers
SOURCE: Have a VR-407 receiver, all of a sudden there's no
Check for basic things like speakers being turned off or switched to speaker b from a and the tape monitor switch being on. Larry's Electronics.
Posted on Apr 28, 2010
  • 532 Answers
SOURCE: Sherwood RX-5502 receiver - get
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
Posted on Jul 11, 2010
ONKYO CD DX-C390 6 CD CHANGER NOT READING
No laser, means no laser. Typical symptom of laser failure. Most CD players can have the laser replaced fairly easily and cheaply.
Contact your local technician, and he should be able to replace it quickly.
Oct 30, 2014 | Audio Players & Recorders
Cd player stopped working
The problem is in the power supply sector of the board, usually caused by a bulging capacitor that needs to be replaced.
Mar 09, 2012 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX C330 carousel goes in and out without stopping and won't quit spinning around
Sometimes the tray ribbon goes bad causing bad connection to main board! Common
problem with alot of brands!
Apr 22, 2011 | Onkyo DX-C390 6-Disc CD Changer
I HAVE A MULTI-DISC CD PLAYER WITH FUZZY SOUND
Digital or analog output? Try the other - same thing? If it improves by switching outputs, suspect teh cable. Also try moving the output to another input on the receiver (?).
Feb 27, 2010 | Onkyo DX-C390 6-Disc CD Changer
I have a onkyo tx sr304 and a onkyo 6 disc player dx-c390.When my cd gets to disc 4 and 5 it shuts the receiver down.Whats up with this?
The only possibility that comes to mind is that it may be causing a short somehow when the carousel gets to that position, maybe a broken solder joint. Another possibility is that there may be a foreign object stuck inside the player such as another disc that lost it's position.
Feb 19, 2010 | Onkyo TX-SR304 Receiver
Onkyo DX-703 CD tray engine tries to oepn but cannot when I put CD player on and hit open. What can I do?
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Gerard
Jan 14, 2010 | Onkyo DX-C390 6-Disc CD Changer
I can't turn on the unit.
no on/off switch on this model; use the remote or load it and press play AFTER you plug it in............
Jun 06, 2009 | Onkyo DX-C390 6-Disc CD Changer
DX-C390 turn on
Use a surge protection power strip (such as the Power Protect AV 600 by Monster Power).
This will elliminate erratic behaviour of the unit, since even minute fluctuations in the power source from unbridled house current will affect the sensitive internal components of the Onkyo DX-C390 6-Disc CD Changer.
Dec 07, 2007 | Onkyo DX-C390 6-Disc CD Changer
27 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
