Question about The Audio Players & Recorders
Got a Thor 64gig MP4 player. Question is, other than the switch, how do you turn the darn thing on???? I noticed a little tab beside the USB port-does that have to come out?
  • 8596 Answers
SOURCE: MP4 Player removable disk doesn't come up
The hold/lock is probably engaged - unlock it; or you are running Vista
go to manufacturer's website and get the Vista-compatible software/firmware if you are running Vista
Posted on Jul 06, 2008
  • 106 Answers
SOURCE: mp4 player doesn't switch on
It may just be that your battery is totally run down, when this happens to me I have to charge it for about an hour before it turns on and the computer is able to read its drive, as for the headphone jack im not sure, try using a different set of phones and a different USB cable to charge it up alot of times the included accessories with these cheap players are faulty.
Posted on Apr 11, 2009
  • 11896 Answers
SOURCE: my mp4 wont connect to my computer
i would search for the latest drivers first. Than I would go to your media player and make sure the device is synced with computer.
Posted on May 22, 2009
  • 3 Answers
SOURCE: notebook compter not recognising my mp4 player
Maybe you need to install some driver, check if your product came with a CD driver or search for the web site of the product. You need to post more information about this mp4 player to help us to help you.
Posted on Mar 03, 2010
  • 99 Answers
SOURCE: my usb ports are not recognized by the sistem
Posted on Apr 29, 2010
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with your MP4 player.
Restarting your PC resets non-functioning USB ports, which may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure you install them.
Try connecting your player to another PC to see if the new PC recognizes it.
If it does, chances are your computer does not support the hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to recognize it.
Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable to get it to work with your PC.
Aug 25, 2013 | Intel Computers & Internet
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
My pc canot detecte my mp4
Your MP4 driver disk must be installed and run BEFORE you hookup the MP4 player.
If you have done the faux pas above, all the installs in the world will not fix it. You MUST remove the USB driver. Use Device Manager. In XP, this is found by right clicking my computer and selecting properties. In properties select the hardware tab and choose 'Device Manager'.
Stop here. If you have no idea what I wrote, review 'Device Manager' on the Windows Website or ask a KNOWLEDGEABLE friend for help. See
Now, select the MP4 device, while it is plugged in to the USB port, and right click. Select 'Uninstall'. Remove your MP4 device when device manager is done.
Close Device manager and all the other windows. Start your USB install from scratch, without the USB plugged in untill the install asks or completes.
I have ALWAYS had successful installs with this method.
Mar 28, 2010 | Ice Tech KEO MP3 Player
I have a 2gig jwin jukeman mp3 player but cannot figure out how to upload music onto the darn thing. The only window that comes up is one for a "avi converter" . How do I get from this window to uploading...
I have an older pc with a 1.0 usb port and a newer pc with a 2.0 usb
port same operating system XP . the 2.0 fine the 1.0 has a malfunction it must be a usb version problem.
Jun 15, 2009 | Jwin Jukeman MP3 Player
Laser mini mp3 player 4GB
I found that MP3 players need to be plugged into a USB PORT not a USB HUB. Good Luck!
Mar 19, 2009 | Laser MVP-1G MP3 Player
MP4 Missil not working
I used real player to get songs on my missil sd-2415 MP4 player. You need to use the driver disk it came with to get it to work. Once you've used the driver you should be able to just plug your player into the computer via the USB cord, open real player Version 11, compatible with Windows XP, although the driver says win 98, it worked fine with my Windows Xp. Nothing really comes up once thr driver has been downloaded, so don't get confused, just follow the driver install wizard and it should be fine. Then on Real player just click on removable disk or player not sure of the exact wording but it's removable somthing the just drag and drop or click to move music from your playlist onto the player.
I had to fiddle around with this player a bit because the instructions are VERY LIMITED! that's putting it mildy but hey it is what it is. This little player is quite neat once you figure out it's little quirks! Good luck!
Dec 26, 2008 | Network Computing Devices (NSH800S/A)...
I need to know how to download music to a mp4 player.
all mp3 and MP4 players have a built in USB port for connecting it to your computer, connect a USB cable to your MP4 player and the other end of the able to your computer's available USB port, windows will recognise the drive and install it for you. all you need to do is to go to my COMPUTER and double click on your MP4 player drive to open the content of your drive
check to see that the drive is has foldes like MY MUSIC, you can use windows media player to sync music files in your library to your MP4 player.
Dec 13, 2008 | Classic Electronics MP6410 MP3 Player
Can't get the usb port to accept the mp4 player.
Switch on your Mp4 player and connect it to the usb port. Your computer should produce a message "New Hardware Detected". If you don't get such a message either the lead, the usb port or the Mp4 player is faulty.
If you do get such a message, if your computer can't find and instal the right drivers automatically there will be another message or the Found New Hardware wizard will appear. By following the onscreen instructions your computer should be able to search the internet for suitable drivers.
In any eventuality, when connected the Mp4 player should appear in the My Computer window and if it doesn't it isn't connected.
Jun 26, 2017 | Samsung YP-T9JQB Digital Media Player
Istage mp4 player
buy one that actualy works
Jun 15, 2008 | Acer MF35 MP3 Player
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
